1966 GTO Calif. engine conversion to 49 state - Pontiac GTO Forum
post #1 of 2 (permalink) Old 05-02-2019, 05:10 PM Thread Starter
Hi, I am changing over my 389 w/4 speed to no A.I.R. pump, eliminating the big air cleaner and smog pump with all its plumbing and long belt. Someone here helped me with what oil cap to use, and I thank them for that, but I lost the message and the admin. didn't reply to my quest for how to recover it. My question is: on cars originally stock w/o smog pump, is the small port on the front of my AFB just capped?(open in second photo) and which big port supplies the PCV? I have an elbow on the manifold by the firing order numbers, and one down in (see photo). I'm thinking of putting a plug where the elbow is. does anyone know what that plug should look like, or have one for sale? Thanks!, Andy
ID:	118671   Click image for larger version
jandyk is offline
post #2 of 2 (permalink) Old 05-16-2019, 04:04 PM
Quoted: 99 Post(s)
Doesn't look like the correct AFB....fuel line is on the wrong side? (been awhile). As for the PCV, you want to use BOTH outlets on the intake. Two short hoses go to a special Tee fitting, and a single line runs to the PCV valve in the valley pan. The reason for this is due to it being a dual plane intake, so the PCV needs a vacuum signal from each portion of the intake. You can install a simple rubber cap plug on the carb. As a side note, intact CA AIR and smog equipment on a CA car adds value to the car....and that equipment is now worth a small fortune to those doing restorations.
1966 GTO conversion to 49 state emission. jandyk 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 03-25-2019 12:34 PM
1965 calif only air cleaner ? blackplate65 1964-1974 Tempest, Lemans & GTO General Discussion 6 02-27-2012 04:25 PM
Hello, from Orange County Calif. Inda_bebe Member Introductions 1 09-11-2011 05:58 PM
difference between CA quadrajet and 49 state? camarocasanova 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 10-28-2008 09:57 PM
Out of state cars brought to Calif njmurvin 2004-2006 GTO General Discussion 6 01-24-2007 04:30 PM
