1967 GTO 400 Harmonic Damper Install - Pontiac GTO Forum
post #1 of 3 (permalink) Old 05-07-2018, 07:20 PM Thread Starter
Hey Guys, new to the site and looking for some help with correctly installing the 2-piece Harmonic Damper. I know i just slide it on the crank snout with woodruff key installed prior to it going on and then tighten the crank bolt with pulley installed. My question is position the Damper with timing marks in reference to piston 1. Do I use the lower 0TDC mark or 6 BTDC mark.
Thank you so much
David
DCRT68 is offline
post #2 of 3 (permalink) Old 05-07-2018, 10:32 PM
Quoted: 106 Post(s)
I don't understand your question, the timing marks are on the hub and are aligned with the Woodruff key.
Goat Roper is offline
post #3 of 3 (permalink) Old 05-08-2018, 03:49 PM
If you're talking about 'moving' the outer ring.... take that balancer and throw it in the trash because it's no good. That ring is not supposed to move at all. The purpose of the rubber bond between the inner and outer parts is to dampen vibration. It's not supposed to ever move.
Harmonic Balancer Install kilkm68 1964-1974 Tempest, Lemans & GTO General Discussion 6 03-29-2015 09:21 PM
pontiac 400 harmonic balancer torque spec? 68gtohawk8369 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 12-16-2012 09:26 AM
proper flywheel and harmonic balancer for 77' 400 SPCMarty 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-29-2012 06:59 PM
A couple questions about swapping my 1967 326/2 speed for 1970 400/400 Crzybone 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 03-25-2012 08:27 AM
1967 GTO header install HELP PLEASE!!!!! hurstmotox67 Intake and Exhaust Discussions 0 08-21-2009 12:16 AM
