1967 GTO but does it have the original engine? - Pontiac GTO Forum
post #1 of 11 (permalink) Old 01-12-2018, 09:11 PM Thread Starter
Hi everyone! We just picked up this 67 GTO (true 242) but I'm having a hard time figuring out if this has the original engine in it. The previous owner stated that it was but I'm just trying to confirm that. It appears to have a YR 400/360 engine in it with a 2 barrel carburetor setup on it. I tried to order the PHS for it but everyone is at Barrett Jackson this week. Any ideas would be greatly appreciated. Thank you!
Shawn
ID:	101745   Click image for larger version
ID:	101753   Click image for larger version
ID:	101761   Click image for larger version
ID:	101769   Click image for larger version
Shawn Middaugh is offline
post #2 of 11 (permalink) Old 01-12-2018, 09:55 PM
Quoted: 31 Post(s)
You will have to do more work but if it Block Casting # 9786135 code YR you may have a ram air block. Check out Wallaceracing.com it will give you more info. Phs will be the real answer but you might of hit a good one, best luck Doug
dd68gto is offline
post #3 of 11 (permalink) Old 01-12-2018, 10:05 PM
Quoted: 31 Post(s)
I just look a little closer at that block. That might be a 350 block ? It's the wrong casting for a400 unless it s mid 70ty 557 which you most likely don't want. I forget where but on block will be a big 400 or 350 on it.. it being a 2 barrel My money its a 350 . Is it a vin number that starts with 242? Not a lemans is it . Good luck but check out Wallace site and get Phs .Doug
dd68gto is offline
post #4 of 11 (permalink) Old 01-12-2018, 10:15 PM
Quoted: 31 Post(s)
Maybe this is yours? 1972 350 160/175 HP YR A 8.0 555 7H1 1-2 7042062 Block Casting # 481990
dd68gto is offline
post #5 of 11 (permalink) Old 01-12-2018, 10:30 PM
Quoted: 367 Post(s)
X2 - looks like 481990 - 1971/72 350 engine. Date will be cast near the distributor hole, 350 will be cast on the side of the block. ID on the heads should be found on the middle exhaust port.
PontiacJim is online now
post #6 of 11 (permalink) Old 01-12-2018, 10:40 PM Thread Starter
Thank you! What does the YR indicate in 71/72 if you don't mind me asking?
post #7 of 11 (permalink) Old 01-12-2018, 10:54 PM
Quoted: 367 Post(s)
1972, 175 hp, automatic, 8.0 compression, 7H1 head casting number.
post #8 of 11 (permalink) Old 01-12-2018, 11:33 PM
Quoted: 31 Post(s)
Shawn I hope the seller just made amistake. The YR code in 1967 if a 400 with correct casting it would have been 360 HP HO motor. A great find. But it looks like you got a 1972 350 Pontiac based off casting number. I'm sure you were looking at complete restoration and 400 are available on market . I would think that 350 is not a motor that you want and I'm not sure what the market is for them. You will find a lot of folks that will help you as you decide what you want to do. Very few gto have the original motor so don't think yours is different than most . It certainly would have added a lot of vslue if it does have the engine it was born with. Best luck Doug
dd68gto is offline
post #9 of 11 (permalink) Old 01-13-2018, 12:23 AM Thread Starter
No sweat! Thank you Jim & Doug. You guys are awesome! Bit of a bummer that it isn't matching but no worries. Still a pretty cool GTO!
post #10 of 11 (permalink) Old 01-13-2018, 03:48 AM
Cafr119's Avatar
Quoted: 38 Post(s)
Nice find, Shawn. 67 is the body style I love about the GTO,I just picked up s 73 GTO and unfortunately it has. 71/72 350 instead of the 400 that it was born with, not sure if the 350 is even any good and it has a TH400 trans which Iím on the fence on what to do, Good luck on your GTO build canít wait to see it done .
Cafr119 is offline
Original engine compression specs GTO vs Grand Prix gtoguy389 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 09-29-2016 09:21 AM
Engine for 1967 GTO Mattzdad Pacific 2 07-16-2012 09:59 PM
1967 GTO Engine Weight revOlg1206 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 05-01-2012 11:30 PM
Original GTO Engine vs Grand Prix 400 EP Goat 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 5 10-28-2011 06:50 PM
1967 GTO engine Bad Banana 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 18 10-29-2009 09:19 PM
