1968 GTO Fan and fan clutch help - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-13-2019, 09:48 PM Thread Starter
Quoted: 4 Post(s)
I have a 68 gto with HO option. Somebody before me changed the fan to one that is to small and not far enough in the shroud.
I would like to put factory setup back.
What was the part numbers for fan and clutch for the HO
Also if I have the correct fan and clutch is there still a spacer required?
Any help here would be appreciated
datahoarder is offline
post #2 of 4 (permalink) Old 05-13-2019, 11:13 PM
BLK69JUDGE's Avatar
Quoted: 63 Post(s)
no spacers on clutch fans
and
are you an ac or non ac car
Scott
BLK69JUDGE is online now
post #3 of 4 (permalink) Old 05-14-2019, 01:30 PM Thread Starter
Quoted: 4 Post(s)
No ac
post #4 of 4 (permalink) Old 05-14-2019, 07:52 PM
Quoted: 367 Post(s)
Originally Posted by datahoarder View Post
No ac
Service Manual says it is a "Power Flex" fan of 19" diameter and has 5 blades. It states the clutch fan uses a 7 bladed 19 1/2" diameter fan and that this was standard on AC cars, but optional on all but the RA engines.
Part numbers I come up with are:
#9779005 - 19" 5 blade - Early 1968 Tempest HD fan. (Also used on non-AC 1967-68 Firebird & 1965-67 full size Pontiac)
#9791346 - 19 1/2" 5 blade - 1968-70 Firebird, Tempest, & full size Pontiacs with HD fan non-AC.
#9784546 - 19 1/2" 7 blade - 1967-68 Firebird, Tempest, & full size Pontiacs with AC.
Note that the parts book lists the early 1968 as 19" diameter which is what the Service Manual states. There seems there may have also been a later 19 1/2" dia fan as well.
PontiacJim is online now
1970 GTO fan/fan shroud Remove rolm 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 01-21-2017 09:25 PM
Fan and Fan Clutch jtwoods4 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 12-14-2012 02:07 PM
Clearance between Radiator Fan shroud and fan jtwoods4 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 07-22-2012 04:51 PM
fan and fan clutch Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 5 04-20-2011 09:09 AM
