1968 gto radiator core support pictures - Pontiac GTO Forum
post #1 of 2 (permalink) Old 04-24-2019, 12:20 AM Thread Starter
These are pics from researching how the 68 radiator core support bushings are configured. The bottom has bolt head, washer, and a rubber support that extends to probably 2 inches as it goes through the core.Then on top of the core support is the female rubber piece that mates to the one coming through the bottom. Then 2 washers the size of the rubber each one about 1/8thĒ thick (I used 3 because I didnít have 2 thick ones). One of the washers is shaped liked a shim and I believe that is for alignment. Probably not necessary could use a shim if needed. Finally the last piece on top of the frame has 3 metal tabs that sit in the frame hole and the bolt from the bottom attaches to it and is tightened securely. Torque? How about 80 lbs. I just made it tight. Hope this makes since and can help.
rond65 is offline
post #2 of 2 (permalink) Old 04-24-2019, 05:17 PM
Quoted: 363 Post(s)
Excellent & clear photos along with a great description. No doubt this will help a few installations in the future.
66 GTO Radiator Core Support A/C 17 1/2" Question Wahoo 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 12-20-2018 04:16 PM
71 gto convertible radiator core support 400goat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 05-29-2017 06:49 AM
New here! Rebuilding a 70 GTO Judge looking for the best radiator core support Vinny 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 01-15-2015 05:38 PM
72 gto radiator core support STOP rusting Goat! 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 04-12-2010 05:12 PM
