1969 gto engine questions - Pontiac GTO Forum
post #1 of 4 (permalink) Old 12-15-2013, 10:33 PM Thread Starter
I recently bought a 79 ta with a 69gto motor in it I'm looking for any info on how to tell what model it came from and what size carb it needs previous owner says current one is undersized also power steering hosee does not seem to be interchangeable any one dealt with this before also any way to tell if my shaker is a functional or not?
thanks in advance
david
mosinov is offline
post #2 of 4 (permalink) Old 12-16-2013, 06:21 AM
David, a lot of the GTOs came with a 750 cfm quadrajet. Welcome. Matt
Matthew is offline
post #3 of 4 (permalink) Old 12-16-2013, 08:51 AM
Orion88's Avatar
The only motor available in 69 for the GTO was the 400. The 455 didn't come out til 70. The only engine variations would be the base, Ram Air III, or Ram Air IV. It is most likely a base or RAIII. If it has the stock quadrajet it's not undersized. It just needs properly rebuilt and set up most likely. Look at the casting numbers on the cylinder heads and that will give you a good idea as to what you've got.
"You Gotta Have Fun When You're Little!!"
-Dick Schindler
Orion88 is offline
post #4 of 4 (permalink) Old 12-16-2013, 06:57 PM
jmt455's Avatar
Welcome aboard.
This is a great resource for engine/heads/manifolds identification:Wallace Racing-Drag Racing Pontiac powered Firebirds,Trans Ams and Dragsters
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
Newbie buying questions for 1969 GTO BigKell 1964-1974 Tempest, Lemans & GTO General Discussion 9 10-13-2012 11:34 AM
1969 GTO ram air iv car need engine waterfire69 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 5 09-17-2012 04:46 PM
1969 GTO engine decoding HELP! Majestic 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 10 02-27-2011 07:41 PM
1969 GTO engine ID help!!! masterclassics 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 8 09-15-2009 09:32 PM
1969 GTO Judge Questions hockeyguy21 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 16 08-13-2009 05:38 PM
