1969 Ram Air IV intake manifold assembly - Pontiac GTO Forum
 1Likes
post #1 of 13 (permalink) Old 11-20-2018, 01:18 PM Thread Starter
Zap69GTO's Avatar
I am slowly closing in on my 1969 GTO RAM AIR IV restoration. I just received the reproduction ram air IV intake manifold, crossover, and crossover housing in the mail. I have a couple questions about the install for anybody that can help. I have searched the internet and can seem to find any literature or device manuals specifically for the ram air IV intake manifold.
1. How does the crossover mount to the engine or intake manifold?
2. The kit I purchased came with crossover covers (2). It appears that the covers go below and above the crossover, shielding it. How do those mount? There was not any hardware included.
3. I am also concerned about the front right mounting bolt hole in the aluminum manifold I purchasedZ It appears that it was machined too close to the edge, leaving less than 1/16 or an inch of “meat.” Do you think this will be an issue?
I am away from the garage right now and don’t have any photos of the build. I will post some as soon as I get home. Thanks in advance
Zap69GTO is offline
post #2 of 13 (permalink) Old 11-21-2018, 01:36 PM
Quoted: 102 Post(s)
Not sure about the shielding, but I would return that manifold. The hole is waaaay off and the manifold will likely fail at that point or at least leak. Demand better for your hard-earned money.
post #3 of 13 (permalink) Old 11-21-2018, 08:16 PM
Agree with GeeTee.. Unfortunately, I've been hearing that all the reproduction RA IV intakes are pretty poor quality - bolt holes off, port alignment off, etc. Looks like that's the experience you're having. I've seen originals on Ebay from time to time but they're VERY pricey. If you want a good one though, you might have to pony up...
post #4 of 13 (permalink) Old 11-22-2018, 01:36 PM Thread Starter
Zap69GTO's Avatar
Thanks for the input guys. I contacted ThePartsPlace this week and they’re response was disappointing. They stated that was normal. I don’t agree with this and will be sending that part back.
With that being said, does anyone have any recommendations for a different intake manifold? I really wanted to restore this car back to the RAM AIR IV it originally was
Thanks!
Happy Thanksgiving
Zap69GTO is offline
post #5 of 13 (permalink) Old 11-22-2018, 03:30 PM
Quoted: 367 Post(s)
Thanks!
Happy Thanksgiving
If me and I really wanted to keep it, a machine shop or fab shop could easily tig weld the hole closed and then using an intake gasket, redrill the hole in the correct position. A machine shop could also make sure all the intake holes are correct and even mill the intake sides should it need to be squared up or have any warping.
Keep in mind that the RAIV intake has the larger intake runner dimensions to match the RAIV heads. So in all reality, the only way out of this is to shell out the $cash to purchase an original RAIV intake if you don't use what you have. I think I'd go with the reworked manifold.
Apparently the aftermarket intake is known to be less than perfect. Check out the note at the bottom of the page in red: SD Performance- Pontiac Performance Specialists
So you might be able to figure out a total cost, the price of the intake plus the rework and see if this is a fair investment versus an original RAIV intake.
post #6 of 13 (permalink) Old 11-22-2018, 11:02 PM Thread Starter
Zap69GTO's Avatar
Thanks!
Happy Thanksgiving
So you might be able to figure out a total cost, the price of the intake plus the rework and see if this is a fair investment versus an original RAIV intake. [IMG class=inlineimg]https://www.gtoforum.com/images/smilies/thumbsup.gif[/IMG]
Thanks Jim! I really appreciate the advice. I will shop around for a good machine shop in my area and see what I come up with.
If I decide to keep the RAM AIR IV intake manifold, do you know where I can look for some literature reference install. I can quite figure out how the crossover and crossover shielding mounts. Thanks again in advance
Zap69GTO is offline
post #7 of 13 (permalink) Old 11-23-2018, 08:19 AM
Quoted: 367 Post(s)
Seems like detailed info is elusive on the installation. Don't know why no diagram was not included nor the flange bolts to hold it on. However, I found that flange bolts are used to secure the intake/crossover. Photo included. You should be able to get these easy enough. Just get the correct length. If you happen to have a Tractor Supply nearby, they do have them and sell the bolts in different lengths and by weight rather than piece - much cheaper.
The Parts Place does have a photo of the intake components assembled, so I would use this as my guide.
Name:	RA IV Flange Bolts.jpg
post #8 of 13 (permalink) Old 11-23-2018, 10:55 PM
I looked through my service and assembly manuals, but did not find any details on the crossover shrouds. The closest I got was to scan this page out of my copy of the GTO Restoration Guide. It doesn't show the fasteners, but I can see what looks like bolt holes on the upper and lower halves of the shroud. I'm guessing that the pieces were either held together by sheet metal screws, or perhaps screws and "jiffy nuts".
post #9 of 13 (permalink) Old 11-24-2018, 08:55 PM Thread Starter
Zap69GTO's Avatar
Thanks Bear! I really appreciate the time and effort. For future reference, each shroud has four holes on the corners. You have to tweak the sheet metal a bit to get them to line up. For now, I just used a bolt, lock washer, and nut to hold it together. Not a fan of how this looks so I’m gonna try a few different things and I’ll update this thread with my progress. Once I start putting everything together I will attach some photos for the next guy.
For now, here is where I am at with the rebuild. Just waiting for my comp cams Magnum 9.300 pushrods to come in the mail.
ID:	116453   Click image for larger version
ID:	116455   Click image for larger version
Zap69GTO is offline
post #10 of 13 (permalink) Old 11-24-2018, 10:12 PM
Quoted: 367 Post(s)
Zap69GTO: "I am slowly closing in on my 1969 GTO RAM AIR IV restoration."
PJ: Hmmmm, what part of a RA IV restoration are Edelbrock aluminum heads?
BearGFR likes this.
Vacuum Routing 1969 Ram Air IV 69GTORAIV 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 9 06-06-2016 04:20 PM
1969 Ram Air IV Intake waterfire69 1964-1974 Tempest, Lemans & GTO General Discussion 14 11-25-2014 04:21 PM
Wanted 1969 Ram Air IV Engine waterfire69 2004-2006 GTO General Discussion 2 11-14-2014 07:45 PM
1969 GTO ram air iv car need engine waterfire69 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 5 09-17-2012 04:46 PM
