326-455 engine swap/ head bolts - Pontiac GTO Forum
post #1 of 4 (permalink) Old 10-31-2012, 10:31 AM Thread Starter
Pulled 326 out of '66 Lemans convertible. Ready to install 455. When I put both engines side by side in the garage, I noticed that the 326 has 2 head bolts on the drivers' side between #1 and#3 cylinders, and between #5 and#7 cylinders which both had smaller studs on top of the bolts for my ground wire and for starter wire tube. The 455 has no studs on the head bolts. Can I: 1) take the bolts out of the 455 4x head one at a time and replace them with the 2 bolts from the 326 w/ 094 heads, or will that compromise the integrity of the new head gasket on the 455? And: 2) Does anyone know if these bolts are the same length on both engines? Need to know asap! THANKS
gjones is offline
post #2 of 4 (permalink) Old 10-31-2012, 02:23 PM Thread Starter
455 head bolt
I guess the real crux of the question is: can I remove head bolts one at a time and replace them without compromising the head gasket?
gjones is offline
post #3 of 4 (permalink) Old 11-01-2012, 12:44 PM Thread Starter
warp the head
Well I reccon there's no good answer, so I'll just do it, and the new head gasket be damned.
gjones is offline
post #4 of 4 (permalink) Old 11-01-2012, 01:15 PM
Quoted: 23 Post(s)
you can run the ground cable to the block in any extra hole just sand paint away before you do and put a little dielectric grease on it, for the starter tube you can mount with bolt just be sure to torque it back to spec and you should be good.
Instg8ter is offline
389 Head Bolts BobDole 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 4 08-18-2012 08:31 PM
Need M11 cylinder head bolts...help! mgfliby Engine Discussions 1 06-27-2012 09:37 AM
head bolts Dan-o Service, Maintenance and Technical Discussion 16 01-09-2012 03:58 PM
Cylinder Head Bolts MaL 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 8 09-09-2010 11:10 AM
Head swap on 1964 389 engine CCLGTO 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 6 01-19-2009 07:11 AM
