389 engine purchase? - Pontiac GTO Forum
post #1 of 9 (permalink) Old 08-26-2012, 06:15 PM Thread Starter
I HAVE A 66 GTO WITH A (1973)400 (093 HEADS) 4 SPEED.I looked at a 389 (YC code 9778789) from a (wrecked) 65 Catalina, 094 heads mild cam, 4 barrel Edelbrock. The owner ran started the engine and it sounds good. Would you recommend this set up in my GTO. Also would the 093 heads make any difference on this block?
4chivos is offline
post #2 of 9 (permalink) Old 08-26-2012, 06:38 PM
If you're interested in performance, keep (and build) the 400 with some good heads. If you're interested in "restoring" the car, then you'll need to find a 389 that has the right data code and engine code to have been 'correct' for the GTO.
post #3 of 9 (permalink) Old 08-26-2012, 08:00 PM
The 094 heads have smaller valves (1.88/1.60) and were installed on the 326 in 1966, the CR was rated at 8.6 and produced 250 hp.
The 093 heads were used on a 389 with 1.92/1.66 valves, the CR was 10.5 with 68cc chambers. HP was rated @ 335 & 360 depending on the carb setup.
In my opinion the 093 heads would be the best choice for the Catalina 389.
05GTO is online now
post #4 of 9 (permalink) Old 08-27-2012, 09:13 AM
Quoted: 118 Post(s)
Again, with 093 heads on a 389, you will need 100 octane fuel or higher. It's about $8 to $10 a gallon out here.
post #5 of 9 (permalink) Old 08-27-2012, 04:15 PM
I'm using 91-93 octane fuel from my local gas station in my 66 GTO with the original factory 389 and the original factory 093 heads without any problems. I rebuilt the engine with the original pistons with a slight bore and milled the heads.
05GTO is online now
post #6 of 9 (permalink) Old 08-27-2012, 05:28 PM
rickm's Avatar
Quoted: 5 Post(s)
i installed a (period correct) '65 389 YF 325 hp. out of a bonneville in my '65gto. it has 76 heads 1.92/1.66 valves. with forged pistons, 068 cam , stock carter afb, stock points dist. it runs beautiful with sunoco 93 octane pumpgas.
rickm is offline
post #7 of 9 (permalink) Old 08-28-2012, 11:38 AM
Quoted: 118 Post(s)
The humidity and 2 octane points help a lot. In arrid California, with only 91 octane fuel, it's no-go. And has been that way for more than 20 years. I am basing my experience on mutiple early GTO's with stock compression, etc....that I've owned and driven. I wish we had better fuel here. If you can get away with stock CR on pump gas, more power to you! I can't make it happen here!
post #8 of 9 (permalink) Old 08-30-2012, 07:58 AM Thread Starter
thanks to all for great advice
4chivos is offline
post #9 of 9 (permalink) Old 09-04-2012, 01:04 PM
in 1966 the valve size was 1.92 and the comp. was 9.2.1, the figures you stated are for 64 and 65. info from my phs papaers
danthepontiacman is offline
some purchase help plz :) Belnick 2004-2006 GTO General Discussion 14 05-27-2011 09:33 PM
Need help with a '67 purchase JustinS 1964-1974 Tempest, Lemans & GTO General Discussion 6 04-17-2010 06:45 AM
looking to purchase a gto 19psi 2004-2006 GTO General Discussion 4 06-29-2006 08:21 AM
looking to purchase devilman2646 Member Introductions 16 02-08-2006 11:53 PM
05 purchase drmustang 2004-2006 GTO General Discussion 25 12-01-2004 05:54 PM
