4 wheel disc brakes. vacuum issues? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 11-05-2018, 07:48 PM Thread Starter
RMTZ67's Avatar
Quoted: 65 Post(s)
So I was thinking of installing four wheel disc brakes on my now all drum brake car. Thinking to myself that while the motor is out now would be much easier install. The question I have is will I have enough vacuum? I have a 67 gto original 400 and have installed a 068 cam. But without having the engine complete not sure what to expect. Opinions/comments appreciated.
RMTZ67 is online now
post #2 of 5 (permalink) Old 11-05-2018, 08:32 PM
The 068 cam has an LSA of 116 which would provide enough idle vacuum for a power brake booster, you will see problems with vacuum and a rough idle when the LSA is below 112,
05GTO is online now
post #3 of 5 (permalink) Old 11-06-2018, 07:05 AM
My65goat's Avatar
Quoted: 18 Post(s)
I have a 65 with power front disc brakes and drums in rear. I have the 389 with 068 cam. No problems, almost 15" vacuum.
My65goat is offline
post #4 of 5 (permalink) Old 11-06-2018, 12:29 PM
Quoted: 135 Post(s)
I have ~ 11" of vacuum but the brakes work great with the booster (I have wired-up a vacuum pump but am not currently using it).
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #5 of 5 (permalink) Old 11-07-2018, 06:10 PM Thread Starter
RMTZ67's Avatar
Quoted: 65 Post(s)
Thanks guys. I was looking at this kit on Ebay for $1200. I am sure There are better/more expensive kits out there but for mostly in town driving (3 speed manual/3:55 gears) It should serve me well.Drum brakes gotta go!
4 wheel vs 2 wheel disc conversion thedford 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 10-02-2017 07:28 PM
Vacuum Hose Hookup at "Rotary Vacuum Valve" rvp986 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 08-29-2015 06:12 PM
Front drum brakes or new disc brakes JTS GTO 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 14 01-23-2015 07:13 PM
67 GTO 4 wheel Disc Brakes novafreak69 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 14 04-16-2014 08:33 AM
Vacuum leaks, vacuum leaks.. KingJacobo 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 11-27-2012 07:51 PM
