400 engine front brackets - Pontiac GTO Forum
post #1 of 5 (permalink) Old 09-26-2013, 04:19 PM Thread Starter
First off, hello everyone! First post here, but been wrenching for a LONG time. Anyway, here's the situation: 1970 GTO convertible, 400, PS, PB and AC. No smog stuff. PO of car stripped the entire front of the engine. pumps, brackets, water pump and housing, everything. I can figure out the crank and water pump pulleys, and I'm pretty sure everything is here, but I have no idea which bracket/spacer/bolt goes where for the rest of the stuff. If someone has a scan from a manual, or something else that can help, I'd VERY much appreciate it!
Thanks in advance!!
speedy5966 is offline
post #2 of 5 (permalink) Old 09-30-2013, 11:07 AM Thread Starter
Nevermind
Got it figured out. When I first looked at that box of parts, it was pretty intimidating. Once I started, though, it went pretty quick.
Thanks anyway.....I guess
post #3 of 5 (permalink) Old 09-30-2013, 08:40 PM
jmt455's Avatar
Glad you got.it figured out so quickly.
I'd suggest you get the Factory Service Manual for your specific year; it has all kinds of great detail you won't find anywhere else.
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #4 of 5 (permalink) Old 10-14-2013, 02:43 PM Thread Starter
Throttle return spring bracket
OK, I got everything figured out except the bracket that the throttle return spring attaches to. It looks like it should go under the drivers side rear carb bolt. but it won't fit, because it interferes with the throttle cable mount bracket. Can anyone post a pic?
Thanks!!
post #5 of 5 (permalink) Old 10-14-2013, 03:07 PM
Jared's Avatar
Quoted: 5 Post(s)
Unless mine is different, the throttle return spring hooks to the bottom of the throttle cable bracket. I apologize for the lousy pictures. I have a very old camera and it is pretty dark in the garage today.
ID:	28297   Click image for larger version
ID:	28305   Click image for larger version
Jared is offline
Front sway bar brackets... PisnNapalm 1964-1974 Tempest, Lemans & GTO General Discussion 16 11-07-2010 05:45 PM
Engine Brackets dakuhns 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 03-02-2010 06:31 PM
