400 engine question - Pontiac GTO Forum
post #1 of 4 (permalink) Old 01-26-2013, 10:38 AM Thread Starter
400 engine question
I'm getting ready to put my rebuilt 400 into my 69 GTO. I can't find a picture so I thought I'd ask the forum. Is there a seal that gets pressed into the block around the end of the crankshaft to seal the flywheel?
funbooker is offline
post #2 of 4 (permalink) Old 01-26-2013, 08:29 PM
chuckha62's Avatar
Quoted: 18 Post(s)
Did you install the crank into the block? ...or did a machine shop do it? The rear main seal is installed in the rear main bearing saddle and rear main cap when the crank is installed. If you installed the crank and didn't install the seal, some disassembly is in order...
chuckha62 is offline
post #3 of 4 (permalink) Old 01-26-2013, 11:29 PM
646904GTO's Avatar
Hopefully if a shop did it they installed the new Viton seal in place of the stock rope seal.
1969 400 T400 auto 2nd owner
1973 Challenger 360/727
1931 Ford Model A
646904GTO is offline
post #4 of 4 (permalink) Old 01-27-2013, 11:40 AM
Quoted: 117 Post(s)
Do a search for 'rear main seal' on this forum and you'll get all the education you could want on the subject. Good luck with your project.
400/350 69 Engine Question funbooker 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 11 12-12-2012 06:26 PM
Engine Question? RustWrangler 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 14 01-12-2012 11:12 AM
67 GTO Engine question ghad14 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 10-12-2010 05:56 AM
455 engine question Cpldavis37 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 02-04-2010 09:24 AM
.040 over engine question trimfixer 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 10-25-2009 03:32 PM
