455 4x heads - Pontiac GTO Forum
post #1 of 5 (permalink) Old 10-21-2012, 12:02 PM Thread Starter
455 4x heads
Pulled old Holley intake off '71 455. In the center of the heads are a square exhaust passage, then directly above that are thin rectangular passages which appear to be cooling passages, which PO just had plugged with silicone. If this is part of the pressurized cooling system, how come it wasn't leaking with just a dab of silicone on it? (Top of intake JUST covered the top of passage). Edelbrock intake going back on, and has the same pattern as the Holley. Is this narrow passage only intended to heat up the intake for cold starts, or is this part of the cooling system? Can I block both of these passages off with metal and industrial strength adhesive? (I don't want any heat source going under my carburetor. It's 90 degrees here in the winter, and I've got an electric choke). THANKS.
gjones is offline
post #2 of 5 (permalink) Old 10-21-2012, 04:58 PM Thread Starter
Anyone???????????
gjones is offline
post #3 of 5 (permalink) Old 10-21-2012, 08:35 PM
jetstang's Avatar
That is the heat crossover, pumps exhaust to heat the carb. I also block it off, I live in FL. No water in the middle. If the intake is the wrong year for the motor it can leave the port uncovered and cause an exhaust leak, trust me, I know. Just block it off and you are good.
Burning rubber since 1982!!
jetstang is offline
post #4 of 5 (permalink) Old 10-21-2012, 09:45 PM Thread Starter
So, out comes the tin snips, sheet metal and industrial epoxy, I guess. ?????
gjones is offline
post #5 of 5 (permalink) Old 10-21-2012, 10:20 PM
69Goatee's Avatar
In the latest issue of "High Performance Pontiac" they show how to block it off with furnace cement. Check highperformancepontiac.com, they might have the article posted, or go buy the Jan 13 issue.
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
RESTORATION IN 1980...
NIN
69Goatee is offline
edelbrock heads or 6x heads bobby326 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 10 08-23-2010 12:40 PM
which heads to pic for my 400 bobby326 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 9 07-20-2010 05:12 PM
Heads+cam REDGTO89 Engine Discussions 13 10-22-2009 09:17 PM
96 heads TinCan 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 01-06-2009 09:40 AM
