65? block information - Pontiac GTO Forum
post #1 of 10 (permalink) Old 10-24-2018, 06:06 PM Thread Starter
Quoted: 6 Post(s)
I know this is not the for sale portion of the forum, but I have a question only. I have a complete engine that was taken from a 65 (i think) GTO, whic also had the 4 speed tranny. I replaced these with a Tremec and a correct 68 block in my 68.
Is there a demand for the early block and trans? The motor was running great but leaked at the rear main and had blowby, after about 14,000 miles put on over about 20 years.
The block has casting 9778789, and stamped 394922 WT
Trans is stamped 241310 and 3851325, maybe 385325.
I gave up the heads along the way so it has a set of 62 castings and a Edelbrock performer intake.
I'm in South Carolina, appreciate your thoughts.
rlitcher is offline
post #2 of 10 (permalink) Old 10-25-2018, 09:32 AM
What's the date code on the block? (4 characters, top, near the distributor hole)
post #3 of 10 (permalink) Old 10-28-2018, 08:18 PM Thread Starter
Quoted: 6 Post(s)
hard to read, 23.5? Hope you see the attachment. I am at a loss about adding atachments or jpg. Tried several times
rlitcher is offline
post #4 of 10 (permalink) Old 10-28-2018, 08:20 PM
Can't quite make out the first character. It looks like either C235 or G235? It matters in this case. The first character is the month: C is March, G would be July. The reason this matters is C-March would mean you have a year model 1965 block, G-July would make it a year model 1966, because the Pontiac engine foundry each year would 'switch over' and start casting blocks for the next year at about mid-year.
post #5 of 10 (permalink) Old 10-28-2018, 08:39 PM Thread Starter
Quoted: 6 Post(s)
Its above, Im sorry not too good at attachments
rlitcher is offline
post #6 of 10 (permalink) Old 10-28-2018, 08:41 PM Thread Starter
Quoted: 6 Post(s)
That is good info, thanks
rlitcher is offline
post #7 of 10 (permalink) Old 11-04-2018, 04:34 PM
Quoted: 102 Post(s)
I'm gonna call that a 'C'...you can verify by placing a piece of paper over the number and rubbing it with a graphite pencil. The numbers will transfer and be more legible.
post #8 of 10 (permalink) Old 11-05-2018, 07:26 AM
Quoted: 135 Post(s)
Are you selling the motor & transmission ? Please PM me if so. Thanks
Chris
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #9 of 10 (permalink) Old 11-05-2018, 01:18 PM Thread Starter
Quoted: 6 Post(s)
not sure how to pm. i aready sold the trans, but have the motor
rlitcher is offline
post #10 of 10 (permalink) Old 11-05-2018, 05:58 PM
Quoted: 367 Post(s)
PM= Personal Message. This is done by first signing in. Then look near the top of the page and you should see in red lettering "Your Notifications." Click on it to bring up a menu of optios and then click on "Unread Private Messages" to take you where you need to go. Then look at the left sidebar and click on "Send New Message." Then just like email, send a PM. This is also where you will check for received messages and can respond.
PontiacJim is online now
65 GTO:need information to connect transmission lines Jjkra 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 11-12-2014 04:59 PM
65 tempest shifter information rpontiacy 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 10-09-2014 02:31 AM
Actual differences between and RA block and non RA block DrBoeing 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 04-26-2010 12:07 PM
326 block and 400 block jbranontn 1964-1974 Tempest, Lemans & GTO General Discussion 2 07-18-2009 10:55 AM
2005 GTO information Troy Roberts 2004-2006 GTO General Discussion 9 08-05-2004 01:38 PM
