66 core support Help / ID - Pontiac GTO Forum
post #1 of 4 (permalink) Old 10-22-2018, 10:08 AM Thread Starter
What is the difference between a AC core support and non AC ?
I have a non AC car but I think I just bought a AC core support.
I looks the same except the bottom is flat piece of steel instead of the c channel bottom that was in my car.
Rookie question, Will it work?
I will post a few pictures later tonight.
Ken
Ken 66gto is offline
post #2 of 4 (permalink) Old 10-22-2018, 04:24 PM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
Yes the AC core has the drop down at the bottom to accommodate the Taller radiator used in AC equipped models.
If you use it you will need a taller rad to work with it, or macgyver your rad to work which would not be a good idea.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 4 (permalink) Old 10-24-2018, 08:36 AM Thread Starter
post #4 of 4 (permalink) Old 10-24-2018, 02:27 PM
Quoted: 98 Post(s)
The upside is you can install the taller radiator and the AC fan shroud and have a much better shot at a cool running engine. It's an upgrade.
66 radiator core support tspring 1964-1974 GTO's and Parts Wanted 5 03-30-2019 05:00 PM
66 GTO Radiator Core Support A/C 17 1/2" Question Wahoo 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 12-20-2018 04:16 PM
64 gto core support is it the same as 65,66,67??? lew64 1964-1974 Tempest, Lemans & GTO General Discussion 1 01-17-2014 01:32 PM
