66 gto distributor issue - Pontiac GTO Forum
 3Likes
post #1 of 29 (permalink) Old 11-23-2015, 01:03 PM Thread Starter
gtoearl's Avatar
Hi again to all, In my prior posts related to timing and tri power carb adjustment issues, your responses were helpful... Unfortunately I've become very frustrated with my attempts to correct my problem so took the car to a well known repair shop here in San Jose,ca. They discovered that my center carb was running way too lean and basically replaced jets and other parts to correct the issue. They have an old school SUN analyzer that measures the exhaust gases to get these readings. Also the rear carb had the ball and spring at the accelerator pump installed incorrectly... What's puzzling to me is that the Dist. has too much total advance... 58-60 degrees. The initial timing is at 12 and seems to run well at that point. They said a new distributor will correct that. I can buy a new one and install it myself....They also said they can rebuild mine, but it would cost more to do that. Correct me if I'm wrong here..... The total advance should be around 38 degrees. The springs in the dist. is to adjust when the timing starts to advance. IE 1400 to 2500 rpm.... There is a bushing that is on the plate and maybe that is missing or needs to have a different one to limit the total advance...??? Would an adjustable vacuum advance can, new springs and bushing, maybe new weights.....would that be the fix to get my total advance down and adjust when the advance starts to come in??? OR just buy a new distributor, Thinking of the pentronic one.. so it would appear stock... Need help guys, thanks..
gtoearl is offline
post #2 of 29 (permalink) Old 11-23-2015, 04:35 PM
Quoted: 98 Post(s)
No worries. If it's a 389, base timing should be 6 degrees, not 12. Very common for the mechanical advance limit bushing (it's plastic) to crack and fall off, giving too much mechanical advance. You can replace this busing easily. I've used cut off nylon vacuum tees to make my own. Ditto for the vacuum advance limit busing....you can install a fatter bushing to limit advance, or make a stop. The adjustable vac. advance cans are junk. Search the web for vac advance limiter plates....they are available. You will have a total of about 48 degrees advance with the vacuum connected at cruise....this is normal. You want about 36 degrees total mechanical at about 3000 rpm. These old cast iron distributors last forever, and with a simple freshen up, are good to go for many more miles. Pertronics is not the answer here....Rebuilding these distributors is not difficult, and can be very rewarding. My advice is to keep the original unit and install new limit bushings and make sure the factory (stiff) advance weight springs are in place.
post #3 of 29 (permalink) Old 11-23-2015, 06:56 PM Thread Starter
gtoearl's Avatar
Is there a rebuilt kit of some kind...springs and bushing, etc..?
Will the limit device that LARS has be the answer for me....?
gtoearl is offline
post #4 of 29 (permalink) Old 11-23-2015, 09:12 PM
Hey Earl,
First of when checking for total advance, make sure that the vacuum hose to the vacuum advance is disconnected and plugged. The term "total advance" can be a little misleading, causing folks to think - well - total must mean everything connected with all the advance you can get. It doesn't. It really means total mechanical advance with the vacuum out of the picture - just like your engine is going to see at wide open throttle under load. Your engine is not making any vacuum at that point, so even with it hooked up the vacuum advance isn't going to be adding anything to the picture. It's not really possible to duplicate those same conditions with the car sitting in your driveway in neutral -- so to get an accurate reading you have to take the vacuum out of the equation by disconnecting it. Under those conditions, you want about 36 degrees total by about 2500 rpm "or so".
But yeah, like GeeTee said, the factory spec for initial timing in these cars is 6 degrees btdc. If after setting it there you still have too much, then the way to take some out is just like you said. Put a bushing (or a larger one) on that pin that limits how much travel is possible in the mechanical advance mechanism. The old timey distributor hop up kits we used to get that came with various different weights and springs usually also included a few bushings of different sizes just for that purpose.
You might be able to get it done with the distributor in the car, but it's a lot easier to do if you just go ahead and pull it, drive out the roll pin that holds on the drive gear, and then slide shaft and all up out of the distributor body. Before you remove it from the engine, pull the cap and bump the starter over until the tip of the rotor is pointing at something you can use for a reference point, so you'll be able to reinstall it in the same position when you're done. It may take some finagling to get it to seat all the way down with the oil pump drive tang engaged because the bevel cut gears tend to move the pump a little when you pull the distributor out, so don't be surprised if you have to install it a few times to 'walk' things around back into alignment.
post #5 of 29 (permalink) Old 11-24-2015, 03:05 PM
Quoted: 98 Post(s)
Earl, yes, Lars has the stuff that you need. Also, he's a real 'go-to' guy and an expert on this stuff. Can't go wrong there.
post #6 of 29 (permalink) Old 11-24-2015, 03:57 PM
Sadly, lars hasn't posted in over a year. Miss his wisdom.
post #7 of 29 (permalink) Old 11-24-2015, 04:00 PM
Quoted: 106 Post(s)
Is there a link for Lars?
I bought a period correct dist. for my '67 but it is non A.I.R and can't find one of these or any info on it.
I bought a kit for it from Ames and figured trial and error to see how it will work.
Does anyone know the difference between the A.I.R and non A.I.R?
Goat Roper is offline
post #8 of 29 (permalink) Old 11-25-2015, 10:57 AM
Quoted: 98 Post(s)
Yes. Google Lars Grimsrud, and all kinds of great articles come up, on Tuning For Beers and Corvette tuning. He's a very, very busy guy.
post #9 of 29 (permalink) Old 11-25-2015, 01:54 PM
Quoted: 106 Post(s)
Thanks, I found the site but it is all about Corvettes and I can't find anything on the net about A.I.R vs. non A.I.R distributors.
The Mallory replacement that was in the car has a floating vacuum advance, I have never seen this before and have no idea why it is like this.
post #10 of 29 (permalink) Old 11-25-2015, 04:28 PM
Lemans guy's Avatar
Quoted: 46 Post(s)
I don't know the difference in AIR vs Non AIR dizzy......but it could be just more centrifugal advance.......
That would allow the base timing to be set at say 4btdc and then pick up the other 32 needed for total advance at the weights in the dizzy.
Why? Because retarded base timing makes your exhaust hotter and burns off the NO......same reason they used ported vac to dizzy at idle, keep the timing retarded at idle and you burn off those pollutants.....
Now anything Lars says cannot be beat, he really knows his stuff. And when you read it you will see that more initial timing and more Vacumn advance at idle gives you a cool runner with lots of pep.
You can run 6btdc like geeteeoh guy says, no problem but it will take a little more advance and run cooler too. As long as it does not ping or knock....a little more sure makes a nice ride. Each car and carb a little different so you have to try it...
Lemans guy is offline
66 GTO Distributor end play tonyli 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 11-10-2015 06:30 PM
MSD distributor and coil install 66 GTO bowdown232 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 02-07-2015 02:17 PM
1972 gto distributor 1972 GTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 01-18-2013 05:44 AM
70 gto Distributor replacement 70gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 03-23-2008 06:58 PM
