66 Tripower - Pontiac GTO Forum
 1Likes
  • 1 Post By geeteeohguy
post #1 of 3 (permalink) Old 04-06-2019, 05:51 PM Thread Starter
66 Tripower
Does anyone know how to tell if a 66 originally came with Tri-Power and when did they stop using it on 66s
golus2 is offline
post #2 of 3 (permalink) Old 04-06-2019, 08:33 PM
Quoted: 364 Post(s)
Get the PHS factory documents for your car. It should tell you which engine was originally installed in your car and if it had tri-power based on the original engine block code. I don't know as there was any kind of cut-off date other than perhaps model year ending.
post #3 of 3 (permalink) Old 04-09-2019, 04:59 PM
Quoted: 99 Post(s)
The engine codes for tripower equipped '66 GTO's were as follows: WS, WV, XS, and YR. WS was manual trans, WV was manual trans CA emissions, XS was man trans and ram air, and YR was automatic. The production of tripower cars was halted in the middle of the production year after the ban on multiple carbs on all GM cars except the Corvette. I do not have a specific date. Less than 25% of all the '66 GTO's came with tripower. The PHS for your car will tell you what yours originally was. One tell is the radiator core support: tripower cars had a thicker support beam than the 4bbl cars, unless they had HD cooling.
Bobbyg likes this.
66 389 tripower timing noluck 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 7 10-27-2016 05:35 PM
66/67 tripower upper radiator hose - HELP 67gteeoh 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 07-11-2009 01:38 PM
Swapping a 66 from the standard 335 to the Tripower? xconcepts 1964-1974 Tempest, Lemans & GTO General Discussion 11 01-12-2009 03:38 AM
