67 Manual to Power Steering - Pontiac GTO Forum
post #1 of 10 (permalink) Old 01-05-2012, 09:26 AM Thread Starter
To convert a manual steering to power steering is it as simple as mounting a pump/pulley, switch the steering box to a power unit, and run the lines? Or is there more involved?
Sent from my DROID BIONIC using AutoGuide.Com Free
67T3MP3ST is offline
post #2 of 10 (permalink) Old 01-05-2012, 11:04 AM
Quoted: 23 Post(s)
The idler arm will most likely need to be changed and the rag Joint coupling may be different depending on what year box you use. I switched to a close ratio unit from a later model GM, and it improved the handling quite a bit.
Instg8ter is offline
post #3 of 10 (permalink) Old 01-05-2012, 12:09 PM
Quoted: 118 Post(s)
The pitman arm is what needs to be changed...and ditto on the rag joint/coupler. The pitman arm is definitely different. Also, coming up with the right brackets (namely the big aluminum one) can be tricky. But, if you have the parts, it's a straight bolt in deal.
post #4 of 10 (permalink) Old 01-05-2012, 03:59 PM
Quoted: 23 Post(s)
My bad....Pitman was what i meant.....DUHHHHHH....I used Lares corporation (Lares Corporation) to get mine sorted out and they were very helpful figuring out what i required for the swap and will have all the parts you need. I would find a used steering box as the new units can get pretty spendy.
post #5 of 10 (permalink) Old 01-05-2012, 05:03 PM
need ps pump, pulley, bracket, steering box with coupling, ps high press hose, return hose, clamps, ps pitman arm, and usually need water pump pulley depending on what alt. ps pulley you use. if AC, uses a different ps pulley and belts for alt and ps.
pontiac is offline
post #6 of 10 (permalink) Old 01-05-2012, 10:31 PM
Quoted: 23 Post(s)
and there are numerous bracket set-ups depending on year and application...sounds so simple.... Be careful putting on the pitman arm on as the steering gear cap is aluminum and can crack if you jar the shaft too much.
post #7 of 10 (permalink) Old 02-07-2012, 10:33 PM Thread Starter
Can someone please post a pic of their power steering pump brackets so I can make sure to buy the right ones
Sent from my DROID BIONIC using AutoGuide.com App
post #8 of 10 (permalink) Old 02-07-2012, 10:34 PM Thread Starter
http://www.ebay.com/itm/1967-69-PONT...-/120854948439
Was thinking these should be everything I need
post #9 of 10 (permalink) Old 02-08-2012, 07:50 AM
Those you linked to look right.
post #10 of 10 (permalink) Old 02-08-2012, 02:41 PM Thread Starter
Thanks for the pic. I will probably get those
1969 Judge manual steering box color Trimuse 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 08-08-2011 09:26 PM
66 gto manual to power steering help johnnylightning03 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 5 11-23-2009 09:05 PM
65 GTo manual steering to power steering? d.reese 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 08-10-2009 06:51 PM
Manual steering 64 GTO lazlo Service, Maintenance and Technical Discussion 2 09-19-2007 07:54 PM
