670 Heads - Pontiac GTO Forum
post #1 of 8 (permalink) Old 07-28-2012, 08:58 PM Thread Starter
zzomby's Avatar
670 Heads
Can I rebuild my 670 heads and bolt them on my 1965 389, or does the valve size not allow me to?
ID:	15367   Click image for larger version
zzomby is offline
post #2 of 8 (permalink) Old 07-28-2012, 09:38 PM
Quoted: 23 Post(s)
compression ratio will be a little high for pump gas on the 389
Instg8ter is offline
post #3 of 8 (permalink) Old 07-28-2012, 10:26 PM Thread Starter
zzomby's Avatar
So I am better off with the $2000.00 aluminum KRE heads I was looking at. Is that the only problem with the install? The size of the valves won't effect anything.
zzomby is offline
post #4 of 8 (permalink) Old 07-28-2012, 11:10 PM
valves are not the issue. Compression is.
pontiac is offline
post #5 of 8 (permalink) Old 07-28-2012, 11:13 PM Thread Starter
zzomby's Avatar
Thank you very much. Unless I can make my own fuel I guess I will sell the 670's
zzomby is offline
post #6 of 8 (permalink) Old 07-29-2012, 01:00 AM
I drive with 670 heads on my 428. Until now no problems and I can't hear detonation. Also the spark plugs look very good, so I guess it can be driven on a 389 as well if you use the best gas available as I do in Austria (100 octane).
Chris-Austria is offline
post #7 of 8 (permalink) Old 07-29-2012, 08:51 AM
Quoted: 23 Post(s)
they will work better on 428-455 with the bigger bores or you could stroke the 389 but thats gonna be more expensive than buying the Alum heads.
post #8 of 8 (permalink) Old 07-29-2012, 09:12 AM
Hang on there zzomby, don't make any hasty decisions until you do a little more research. As far as physical installation of the 670's on your 389 there are two issues you might run into.
* One is that "at some point" (I forget when exactly) Pontiac changed the inclination angle of the valves slightly. That means the location and shape of the valve relief pockets in the piston tops might not line up correctly with the valves. There are some "Frankenstein looking" aftermarket pistons out there that actually have valve relief's in the for both angles (two complete sets of reliefs in each piston) but they aren't good for a performance build.
* Two is that the valve clearance notches in the tops of the cylinder bores might not be right for the 670's.
Both those problems are (relatively) easy to solve though and not a reason to toss the heads.
As far as compression, yes you need to be careful there but in general putting "small chamber" 72 cc heads on a smaller displacement engine results in less compression, not more. (Compression goes up when displacement goes up, head chamber volume remaining constant).
What you'd need to do would be to get actual measurements for your engine including bore, stroke, piston deck clearance, and compressed head gasket thickness then calculate where you'd be on compression with the 670's. You want to measure the chamber volume on them too so you'll know what they really are. Standard dimensions for a 389 are 4.06250 bore by 3.750 stroke but if yours has been overbored by a previous rebuild that will figure into the calculations.
(I'd run the calculations for you through my spreadsheet using "normal" dimensions but I'm away from home right now and don't have it with me.)
Larger valves are a good thing.
Specific to the 670 heads beside the fact that they've got the big valves and screw-in rocker studs, is that they're the last "closed chamber" performance head Pontiac made. They are very popular with some engine guys, but personally I've never quite understood why. They do flow well for D-port heads, but those closed chambers hurt combustion efficiency meaning that they need more ignition advance to be "happy" than an open chamber head does. More advance means more opportunity for "negative work" in the cylinder -- you're building combustion pressure before piston TDC and that's working against making power. That closed chamber though means they've got a huge quench pad area and that does tend to promote lots of turbulence in the mixture and that's a very good thing for helping to avoid detonation.
Compression ratio and related topics tends to polarize people into two camps. Those who tend to push compression ratio right to the razor's edge and those who shy away from doing that. Both sides have some very good arguments and some folks on both sides are very successfuly at building engines that live and also make significant power. I tend to be cautious with it myself, but I also try to be objective and sort through the 'chatter' to understand the truth underneath it all.
There's more than one way to build a Pontiac that makes power.
Just a heads up! GuatoLT1 2004-2006 GTO General Discussion 0 01-27-2011 04:35 PM
edelbrock heads or 6x heads bobby326 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 10 08-23-2010 12:40 PM
#96 heads or not? assasn2k 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 03-11-2009 06:42 PM
