69 exhaust manifold on 68 400 - Pontiac GTO Forum
post #1 of 6 (permalink) Old 05-31-2018, 08:14 AM Thread Starter
deanhickey's Avatar
Quoted: 38 Post(s)
Good morning All, I have run into a little problem, while dismantling my 68-400 engine and checking dates and numbers I discovered my left side exhaust manifold was from a 69 (9782810-a) date code J029.
Will this exhaust manifold restrict flow on my 68? I have noticed the ports on the 1 and 5 cylinders is fairly small and round compared to the head. the head matches the engine and the car.
Does nay one know where I might be able to purchase a correct 68 manifold.
Hope the water is nice where you are today.
Enjoy
deanhickey is offline
post #2 of 6 (permalink) Old 05-31-2018, 10:27 AM
BLK69JUDGE's Avatar
Quoted: 63 Post(s)
whats the date on your other manifold ,,,, so we can check our stashes
BLK69JUDGE is online now
post #3 of 6 (permalink) Old 05-31-2018, 11:00 AM Thread Starter
deanhickey's Avatar
Quoted: 38 Post(s)
the Date stamp L277 (Dec 27 67). the engine date is A128 (Jan 12 68) so I believe the right on is original.
Thanks for looking.
post #4 of 6 (permalink) Old 05-31-2018, 05:53 PM
Quoted: 367 Post(s)
Wallace has the casting numbers. Your left appears to be a 1969 GTO, so most likely the same as the '68 ports. Pontiac Exhaust Manifolds - Wallace Racing
Measure the outlet size to see if they are the same. The end ports are round. Check out this gasket - https://www.carid.com/1968-pontiac-g...231314819.html
Here is a picture of the correct 1968 GTO - left side: https://www.partrequest.com/auto-par...-391887962509#
For performance, unless you gotta have original, upgrade to the better Ram Air manifolds.
PontiacJim is online now
post #5 of 6 (permalink) Old 05-31-2018, 08:39 PM Thread Starter
deanhickey's Avatar
Quoted: 38 Post(s)
Thanks Jim , The manifold is the only part of the engine which does not match, will run with it until I find the correct one.
post #6 of 6 (permalink) Old 06-12-2018, 11:17 AM Thread Starter
deanhickey's Avatar
Quoted: 38 Post(s)
Just checking to see if you found a exhaust manifold for December 1967.
72 400 intake manifold studs tjs72goat 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 02-18-2018 08:36 PM
Standard Manifold to Ram Air Manifold exhaust upgrade Lemanster70 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 12 07-30-2016 11:54 AM
Exhaust Manifold Krets 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 12 02-28-2016 12:36 AM
exhaust manifold klem Gtoforum.com Site Help 0 12-09-2015 01:13 PM
exhaust manifold maktope 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 7 08-10-2013 09:44 PM
