69 GTO 455 swap - Pontiac GTO Forum
post #1 of 2 (permalink) Old 02-17-2018, 02:12 PM Thread Starter
Mark8117's Avatar
69 GTO 455 swap
Need some help, I am sure someone out here as this.
Picked up a 69, has a 455 w/eddy aluminum heads. Picked up some hooker super comps headers and it is REALLY tight. Looks like we need to notch the drivers side frame for the back tube to get clearance.
Before we start doing surgery, Iím wondering if the engine mounts are different for the 455 vs 400. This is my first GTO so Iím not sure.
Thinking whoever started this didnít use the correct mount
Any help is appreciated
Mark8117 is offline
post #2 of 2 (permalink) Old 02-17-2018, 06:39 PM
Quoted: 55 Post(s)
A 400 & 455 should use the same mounts, in a '69 body.
Back in the old days, I used some Hooker round ports, on a 455 with RAIV heads. Used the same mounts as what came on the car. It was a '69 RA3 GTO. Never had any header to frame clearance problems, with 400 or 455 engines, and either D-port or round port heads. Used both Hedman & Hooker headers.
There are probably some guys around who can cut out a section of the tube and reshape it, for clearance. My engine guy has made lots of header tube changes. But, I suppose the possible changes would depend on the particular header and exactly what change is needed.
bigD is online now
455 swap with tripower WildTom65 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 01-07-2016 03:10 PM
326-455 engine swap/ head bolts gjones 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 11-01-2012 01:15 PM
400 or 455 swap into '66 Lemans JB_Finesse 1964-1974 Tempest, Lemans & GTO General Discussion 4 07-15-2009 08:41 AM
69 GTO 455 engine swap pbkgto 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 8 04-16-2009 08:34 PM
389/455 swap gtocrazed 1964-1974 Tempest, Lemans & GTO General Discussion 2 05-27-2008 09:13 PM
