72 400 engine head bolts - Pontiac GTO Forum
post #1 of 3 (permalink) Old 11-09-2017, 04:05 PM Thread Starter
Quoted: 33 Post(s)
I'm having my engine rebuilt. It was in pieces when I bought the car. It's original to the car with AC. My builder asked which head bolt may have the stud for the heads. Apparently for accessories. It's a 400 with 7k3 heads.
tjs72goat is offline
post #2 of 3 (permalink) Old 11-09-2017, 04:20 PM
Tjs, the following spots take studded bolts:
Long studded bolt:
- Above number one Cyl exhaust, ground cable, attachment, castellated nut
- Above center exhaust on passenger side (between 4 & 6 exhaust)
- if you have three of these long 3 3/4" studded bolts, one above number 2 Cyl exhaust port
-shorter studded bolts, on driver side of head. two of them towards the middle that ex preheater shroud attaches to.
-under valve cover two on each head, that factory oil droppers bolt to.
have not forgot about you on checking hood springs, looked before went out of town, & will look again through more hood hinges this weekend.
post #3 of 3 (permalink) Old 11-11-2017, 12:43 PM Thread Starter
Quoted: 33 Post(s)
Thanks PH. Appreciate your help.
Head Bolts hayes68gto 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 2 04-04-2013 11:10 AM
326-455 engine swap/ head bolts gjones 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 11-01-2012 01:15 PM
389 Head Bolts BobDole 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 4 08-18-2012 08:31 PM
head bolts Dan-o Service, Maintenance and Technical Discussion 16 01-09-2012 03:58 PM
Thin Head Gaskets For 1975 400 engine beertracker 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 6 11-20-2009 12:58 PM
