72 400 intake manifold studs - Pontiac GTO Forum
post #1 of 4 (permalink) Old 02-12-2018, 06:56 PM Thread Starter
Quoted: 33 Post(s)
The intake has studs on the front two passenger side holes for ac bracket. Looking at a 73 400 I have, shows one on the driver side on second from front hole for alternator bracket. There is a fourth at the rear of driver side. What is that location stud used for?
tjs72goat is offline
post #2 of 4 (permalink) Old 02-13-2018, 05:09 PM Thread Starter
Quoted: 33 Post(s)
Found it on another site. Throttle bracket.
post #3 of 4 (permalink) Old 02-13-2018, 06:27 PM
The throttle cable bracket is of a new compact design for '72, the short legs bolt with two small bolts straight down to the intake. '70 & 71's (exc '71 455 HO Ram air) use the A-G stamped 4 bbl throttle bracket where one leg is bolted to the studded intake bolt. '69 and '68's used the T-4 4bbl throttle bracket, same attachment. Earlier GTO & v8 Tempest/LeMans used similar brackets, mounted in like manner. On a points ignition '72 Pontiac V8, that small studded intake bolt can only mount a mtg bracket for the coil. The '72 I have the most detailing experience on is my T/A's factory unitized distrib WM engine. Will confirm on the Lux LeMans partscar, it is totally original.
post #4 of 4 (permalink) Old 02-18-2018, 08:36 PM Thread Starter
Quoted: 33 Post(s)
I have a 73 engine on a stand and it has that rear stud also. So that would also be for a coil rather than a throttle bracket? That same engine also has an hei distributor. But, it may have been added by a previous owner I got this car and the original motor I'm building from.
Rocker studs through intake runners mrbill 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 6 12-31-2014 01:46 PM
Intake manifold avery310 Intake and Exhaust Discussions 8 10-26-2013 10:30 AM
Intake manifold orelog 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-06-2013 02:38 PM
