7K3 Heads 1971 - Pontiac GTO Forum
post #1 of 2 (permalink) Old 08-07-2012, 08:43 PM Thread Starter
speedracer25f's Avatar
7K3 Heads 1971
What would a set of 7K3 be worth? I know that you cant run headers with these, just manifolds. Any other problems with these heads?
speedracer25f is offline
post #2 of 2 (permalink) Old 08-07-2012, 10:57 PM
Who says you can't run headers? You just have to get the right kind (D-port headers, not round port). 7k3's --- big valves (2.11/1.77), screw in studs, and 96cc chambers (nominal). Put those on a 461 with flat top pistons, run a 0.040" compressed thickness head gasket, zero deck the block, and you'll be at 9.517:1 static compression ratio. Add a cam with some attitude and a 'later than usual' intake closing event and that's dang near perfect. Flat tops and zero-decking will give you good quench area for lots of turbulence and minimal exposed edges in the chamber --- both very good for detonation resistance.
If you're going to run iron d-ports on a big inch Pontiac, that's about as good as it gets.
1971 455 ho? skapegoat 1964-1974 Tempest, Lemans & GTO General Discussion 6 12-16-2013 09:12 PM
edelbrock heads or 6x heads bobby326 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 10 08-23-2010 12:40 PM
1971 1/2 Gt-37 D1147 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 01-25-2010 09:08 PM
