air cleaner problem - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-17-2017, 07:39 PM Thread Starter
Kim_Francis's Avatar
air cleaner problem
Hi guys!
So i started to change the air filter on the 73 LeMans 350 and when i opened the housing i found the air cleaner kind of like glued to the bottom lid... the air filter is very old and dirty and wanting to replace it i was a bit upset because it is kind of ruined. After that my friend give me an Edelbrock pro flow air cleaner that is supossed to fit there but the original one has some cable in the inside and thermo something outside on the snorkel.. are these elements importants? should i try putting them somewhere? Also there is a rubber hose connected from the air cleaner bottom to the valve cover, i read about putting valve cover breathers so should i put a breather with the new air cleaner?
Thank you!
Kim_Francis is offline
post #2 of 3 (permalink) Old 12-18-2017, 10:35 AM
1968gto421's Avatar
Quoted: 70 Post(s)
The factory air cleaner was designed as part of the emissions control package. There was a synthetic hose attached to the bottom of the snorkel going to a shield on the exhaust manifold. When the engine was cold it drew warm air from around the exhaust manifold to assist with warm up and better fuel atomization, When warmed up, the thermo thing on the snorkel closed a flap in the snorkel and cool air was dawn through the end of the snorkel.
MOst Edelbrock air cleaners have a punch out on the underside of the airclaener to attach a fitting (see link------ Edelbrock Crankcase Breather Filter Connection Kit | JEGS )
You can attach a hose to this fitting and to the pipe coming from your valve cover to retain the factory PVC/breather set up.
Hope this helps!
1968gto421 is offline
post #3 of 3 (permalink) Old 12-18-2017, 03:16 PM
the "Pro flows" are one of the triangular mesh air cleaners with foam inside. Absolute junk, just like the similar design Weiand aircleaners before them. All it takes is a backfire & you have half melted plastic debris in the carburetor. Does your '73 350 still have its 2bbl carburetor?
Air cleaner 69GTOCONVLOVER 1964-1974 Tempest, Lemans & GTO General Discussion 7 01-05-2014 07:55 AM
air cleaner Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 10 10-30-2011 07:01 AM
air cleaner and A.I.R. Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 1 02-19-2011 05:39 PM
Can anyone ID this air cleaner? Edelbroke 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 02-05-2010 10:18 PM
Air Cleaner ID Frank Rossi 1964-1974 Tempest, Lemans & GTO General Discussion 4 01-23-2009 09:06 AM
