Ambient switch for 70 GTO - Pontiac GTO Forum
post #1 of 5 (permalink) Old 08-30-2018, 12:45 PM Thread Starter
Bobs70GTO's Avatar
I'm trying to find out if there are ambient switches available for my 70 GTO. I've had no luck finding either NOS or replacement parts for this item. As you can see from the attached photo, when I removed my original switch to refresh my engine compartment, it broke where the screw hole was. Any clues or help finding one in good shape is appreciated.
Bobs70GTO is offline
post #2 of 5 (permalink) Old 08-30-2018, 06:08 PM
Quoted: 361 Post(s)
If it were me and the switch still worked, I would fix it.
JB Weld your pieces together and then sand smooth. Get a thin piece of aluminum, or even sheet metal, cut to same size/shape of that switch with a neat rectangular hole to slip over the electrical prongs. Then put a thin layer of JB Weld on the back side of the plate, and press on/over the top to hide the cracked end and use your finger to blend in the JB Weld at the rectangular opening (like doing body work here) and the edges. This will secure it firmly to the ambient switch. Let it cure up a couple days, then sand the edges smooth, sand the rectangular area a bit, and then drill your mounting holes through the switch attachment holes in the sheet metal. Paint with a 60% gloss black and it will look as new. Doing this will provide support under the sheet metal by JB Welding that broken ear on while really relying on the sheet metal to secure the switch in place as you snug down your original bolts.
No one will even notice it and you can brag that you found the last NOS ambient switch know to exist in the Pontiac world and it cost you about as much as the car is worth.
post #3 of 5 (permalink) Old Today, 01:57 PM
You were able to locate a supplier - in need of one for 69. BTW - did you have a part number, only one I could locate was 9792638.
dewaynewilson is online now
post #4 of 5 (permalink) Old Today, 03:23 PM
BLK69JUDGE's Avatar
Quoted: 62 Post(s)
I may have a nice used one under a hood
wont be able to check till saturday when I am out at the parts cars
BLK69JUDGE is online now
post #5 of 5 (permalink) Old Today, 05:39 PM
Quoted: 9 Post(s)
PARTS???
Red Skeleton is online now
Currently Active Users Viewing This Thread: 6 (2 members and 4 guests)
BLK69JUDGE, gtogoober
Ambient sensor/switch theheed08 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 Today 02:01 PM
Save 20% on Interior LED Ambient Lighting Kits at PFYC.com PFYC Interior Discussions 0 01-19-2012 10:00 AM
New Product: LED Ambient Interior Light Kits - 10% OFF at PFYC PFYC Interior Discussions 0 10-06-2011 03:35 PM
Location of Rear quarter Power Window switch for 70 GTO Convertible GQUINCOCES 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 0 02-09-2009 12:19 AM
