Best rear main seal? - Pontiac GTO Forum
 2Likes
  • 1 Post By bigD
  • 1 Post By geeteeohguy
post #1 of 4 (permalink) Old 04-29-2019, 02:11 AM Thread Starter
Hi everyone
Novice question alert!
I've read a few older posts about the best rear end seals to use. Seemed the discussion back then involved two favourites:
1. Graph Tite Seal" from the "Best Gasket Co. https://bestgasket.com/vintage-engine-gaskets/
2. The Viton One-Piece Rear Main Seal from BOP Engineering BOP Engineering Pontiac Replacement Parts
Both of these options were fairly new when the discussions I saw were posted, so it was hard to get a feel for the better option of the two.
Is there a clear preference emerged now they have both been in the market for a while?
Any guidance would be much appreciated!
johnv is offline
post #2 of 4 (permalink) Old 04-29-2019, 08:27 AM
Quoted: 59 Post(s)
The 1-piece seems to be the favorite of most.
But, some engines REQUIRE the rope, for certain reasons.
https://www.gtoforum.com/f50/67-gto-...-gasket-34376/
So, I'd say the 1-piece is the best choice, if it'll work in your particular engine.
http://www.pontiaczone.com/forum/showthread.php?t=30751
johnv likes this.
bigD is online now
post #3 of 4 (permalink) Old 04-29-2019, 03:34 PM Thread Starter
Excellent, many thanks bigD. Those are great links!
My GTO is a 68 convertible so am hoping the 1 piece is the answer... altho I clearly need to take a good look at the oil pan gasket first!
johnv is offline
post #4 of 4 (permalink) Old 04-29-2019, 05:22 PM
Quoted: 102 Post(s)
Have installed several BOP 2-piece and one BOP 1-piece on 389's and 400's. No leaks on any of them after several years and many miles. Not a drop. However, if you have a big-journal 421-428-455 engine, the Best-Gasket square section rope seal seems to be the best choice. Due to crank diameter and main cap design, the Viton BOP seals seem to have issues sealing these engines up.
johnv likes this.
67 GTO rear main oil seal use viton or best gasket fiesta62 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 10-13-2011 12:22 AM
Rear main seal replacement tv66 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 10-04-2009 08:17 AM
68 Gto Rear Main Seal Leak khinton 1964-1974 Tempest, Lemans & GTO General Discussion 16 03-14-2009 06:01 PM
Rear main seal 66 GTO Kentucky_GTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 04-26-2008 07:07 PM
