Brake Booster Vacuum Line '67 GTO - Pontiac GTO Forum
post #1 of 10 (permalink) Old 04-28-2018, 07:25 PM Thread Starter
Brake Booster Vac Line '67 GTO & PCV Grommet
400 CI engine in a '67 GTO.
What does the metal line look like that attaches at the base of the carburetor onto which one fastens the 3\8" hose routed to the brake booster?
There seem to be two options. https://www.npdlink.com/store/?p=cat...0000&year=1967
Secondly, where does one get the rubber grommet that secures the PCV valve in front of the distributor mounting location? My PVC is rattling badly because the grommet is like hard plastic.
Andrew69 is offline
post #2 of 10 (permalink) Old 04-28-2018, 08:09 PM
Quoted: 106 Post(s)
Grommet here, part #N210A
https://secure.amesperf.com/qilan/Se...rd=PVC+&sort=0
Booster line C-4930-454AA is original carbon steel, C-4930-454AS is stainless.
Go with the original, the stainless is harder and won't seal as well.
Goat Roper is offline
post #3 of 10 (permalink) Old 04-28-2018, 08:16 PM Thread Starter
Thank you. Is the grommet something I could get at my local NAPA parts store? This seems to be it. https://www.napaonline.com/en/p/CRB29105
Andrew69 is offline
post #4 of 10 (permalink) Old 04-28-2018, 08:20 PM
Quoted: 106 Post(s)
post #5 of 10 (permalink) Old 04-28-2018, 08:21 PM
Quoted: 106 Post(s)
I don't know, I got mine at Ames.
post #6 of 10 (permalink) Old 04-28-2018, 08:23 PM Thread Starter
Thank you. I fortunately have the fitting but the tube on the car doesn't look right.
Andrew69 is offline
post #7 of 10 (permalink) Old 04-28-2018, 08:30 PM
Quoted: 106 Post(s)
I didn't know if you had the tube so I figured I would show the fitting as well, it would suck to get the tube and not have the fitting.
post #8 of 10 (permalink) Old 04-28-2018, 08:36 PM
Quoted: 106 Post(s)
Take the original grommet into NAPA with you and match it up, that looks like it.
post #9 of 10 (permalink) Old 04-29-2018, 06:20 PM
Grommet from Orilley's - Dorman P/N 42054
1967GeeTeeOh is offline
post #10 of 10 (permalink) Old 04-30-2018, 03:51 PM Thread Starter
[url]https://secure.amesperf.com/qilan/Search_Web?order_number_e=NDU0MzI2Mg%3D%3D%0D%0A&m ethod_1=&method_2=Y&on=Y&search_method=2&cat_rowid =1&search_year=1967&search_keyword=PVC+&sort=0[/url
Today I ordered a new grommet, PCV valve, brake booster vac line and a few other miscellaneous parts from AMES. Thanks for the link. AMES seems to be good people. This grommet seems to be the unicorn of GTO parts as I could not find it elsewhere.
Andrew
Andrew69 is offline
67 gto vacuum line question Gramps 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 03-14-2018 03:36 PM
66 gto ac vacuum line diagram needed azaapcom 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 32 02-13-2018 07:40 AM
Brake Booster/Vacuum Line Issues, 67 Tempest DanT 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 5 07-19-2013 08:20 AM
need some Mastercylinder, brake booster, and brake line advice virginiavenom 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 13 05-14-2011 08:37 PM
64 GTO vacuum line diagram greengrad1977 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-01-2010 07:58 PM
