Can a 1967 intake valley pan be chromed? - Pontiac GTO Forum
 3Likes
post #1 of 13 (permalink) Old 07-01-2018, 10:26 PM Thread Starter
RMTZ67's Avatar
Quoted: 64 Post(s)
UPDATE :I am rebuilding my engine so it will have a fresh new paint. It will also have the oem chrome valve cover, chrome carb air cleaner, chrome stock capacity oil pan and polished chrome ceramic coated headers. So I thought it might be a nice touch to have the valley pan chromed. Do they have any type of baffles in them that would get ruined? Or maybe I can put some type of metal plug in the rear hole. I dont want anymore chrome than that or it starts looking cheesy. thanks
RMTZ67 is online now
post #2 of 13 (permalink) Old 07-01-2018, 11:33 PM
Quoted: 126 Post(s)
Not exactly baffles and nothing that would get damaged from chroming....
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #3 of 13 (permalink) Old 07-03-2018, 09:44 AM
Quoted: 106 Post(s)
Basically a clamshell so no problem with chroming it.
I would make sure to straighten the mating surfaces on the sides and fit it before chroming.
Goat Roper is offline
post #4 of 13 (permalink) Old 07-06-2018, 01:21 PM
Quoted: 98 Post(s)
No issue with chroming that part. But, it will be hard to keep polished and chrome sealing parts tend to leak more than painted stamped steel. The chrome is super slick and lets the oil out. My '65 has a ton of chrome under the hood that was done in the '70's when it ran a 428: chrome heater core cover, hood hinges, balancer, timing cover, balancer, PS mounts (that is a HUGE one), hood hinges, latch, and on and on. Most remained when I installed the 389 later on, and I've left it, but it is a PITA to keep looking great on a driven car. And now, it brings attention to how GRIMY my old carbs and manifolds are!
post #5 of 13 (permalink) Old 07-10-2018, 10:07 PM Thread Starter
RMTZ67's Avatar
Quoted: 64 Post(s)
chroming valley pan
Thanks for the good info guys. I will purchase a new one and mate it to the block and intake and take a abrasive wheel to the gasket area after chroming as well.
post #6 of 13 (permalink) Old 07-10-2018, 11:13 PM Thread Starter
RMTZ67's Avatar
Quoted: 64 Post(s)
valley pan
So I was gonna buy a new one and have it chromed but was wondering. can I just use gas to clean out the old one? nothing fits better than oem. I can also use that money to chrome.
deanhickey and cij911 like this.
post #7 of 13 (permalink) Old 07-11-2018, 07:29 AM
Quoted: 126 Post(s)
Yes, that is how I cleaned mine....
Current setup:
4 speed Muncie
cij911 is offline
post #8 of 13 (permalink) Old 07-16-2018, 06:25 PM Thread Starter
RMTZ67's Avatar
Quoted: 64 Post(s)
I was wondering if you had a chrome oil pan on the 65. And if you had an leak issues. I bought this pan and it was a more expensive one and stated it was correct capacity. But if you look at the picks of the difference where the rear seal goes. Anyone else can chime in if you installed a chrome oil pan.
ID:	114181   Click image for larger version
post #9 of 13 (permalink) Old 07-16-2018, 07:15 PM
Quoted: 361 Post(s)
The new pan uses the later 3-prong gasket at the rear. Look at the photo, lower right gasket is what you want. https://www.bopengineering.com/ponti...t_parts4.shtml
They also have the 1 piece oil pan gasket.
post #10 of 13 (permalink) Old 07-16-2018, 07:26 PM Thread Starter
RMTZ67's Avatar
Quoted: 64 Post(s)
oil pan gasket
I feel better now. Thanks
Trunk Floor Pan - can I use a 67 chevelle trunk pan in my 67 GTO SOCMedic 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 01-19-2015 08:30 PM
valley pan 68gtohawk8369 1964-1974 Tempest, Lemans & GTO General Discussion 5 05-10-2010 02:56 PM
'66 Valley Pan color? MaL 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-09-2010 09:33 PM
Valley pan in a 400ci dlloyd443 1964-1974 Tempest, Lemans & GTO General Discussion 2 11-16-2008 01:53 PM
