Carb Selection - Pontiac GTO Forum
 1Likes
  • 1 Post By Lemans guy
post #1 of 6 (permalink) Old 03-04-2019, 09:32 PM Thread Starter
vera_jr's Avatar
Carb Selection
I have a newly rebuilt and bored out 455 that is going in my 69 GTO. I went with a slightly larger cam, new lifters, springs, ground down crank shaft, the works. I am replacing all the components that have anything to do with running through the engine. Fuel system, radiator, and Carb! I have narrowed down two carbs that I am debating on and am wondering if anyone has had any good or bad experiences with them. They are the Quick Fuel 750 Brawler or the Demon 750 Street Demon.
JR
'69 GTO 455
vera_jr is offline
post #2 of 6 (permalink) Old 03-04-2019, 10:07 PM
Quoted: 55 Post(s)
I & many other Pontiac guys recommend a properly rebuilt 800cfm Q-jet.
But, if you're dead set on a square bore, a guy here did some carb testing, for his 400, & chose a Quick Fuel SS-680-VS. So, for a 455, a QF SS-780-VS might be a good choice.
https://www.gtoforum.com/f178/opinio...tml#post624025
https://www.gtoforum.com/f178/opinio...tml#post624121
https://www.amazon.com/gp/offer-list...&condition=new
bigD is online now
post #3 of 6 (permalink) Old 03-05-2019, 06:58 AM
Lemans guy's Avatar
Quoted: 55 Post(s)
Vera, Bigd is correct on that assessment
I run a QFT SS 780 VS Black Diamond......that coating is for heat reduction, looks great to.
You can tune each circuit easily and runs super. Parts, jets, restrictors, air bleeds, all easy to get. You can make it run with the perfect AFR in every power circuit.
Lemans guy is offline
post #4 of 6 (permalink) Old 03-05-2019, 11:24 AM Thread Starter
vera_jr's Avatar
What about the Quick Fuel Hot Rod Series? They have the same specs, but are about $300 less.
JR
'69 GTO 455
vera_jr is offline
post #5 of 6 (permalink) Old 03-05-2019, 12:11 PM
Lemans guy's Avatar
Quoted: 55 Post(s)
yes I believe they have the same features that matter, as far as adjustability. The SS series may have some billet metering blocks etc. Compare the features, but QFT carbs are super adjustable carbs and run great. I prefer them and parts are easy to get from QFT which is in Bowling Green Kentucky.
The QFT story is that Holley engineers wanted corporate to make changes and inprovements on carb adjustability, ez change of air bleed, PVCH, IFR etc. but could not get it through. So they left and started their own company QFT. They were very successful and lots of folks loved the new QFT. Holley then bought the Company.
That is how I heard it, I am sure there is some nuances to all that, but nevertheless. Holley is a great company and QFT is their subsidiary. EZ to get parts.
Call their line they are very helpful.
vera_jr likes this.
post #6 of 6 (permalink) Old 03-13-2019, 08:55 PM
Tropical Goat's Avatar
I put a 750 Street Demon on my 67 400 a while back...and my advice to you is...don't go there!..."off the line" It had a bog or pop I just couldn't tune out of it...even after dumping like 60.00 more on the dinky tuning kit...although, after the "bog" it roared and ran like gangbusters. Reading some buyers opinions, I found plenty of folks who were happy with it..but others had my same problem...it seems pump shot related...In short, do you wanna risk it?...plus it won't fit a drop base air cleaner without a spacer that makes it a bit too tall.
If it were really good, I'm sure we'd be seeing and hearing a lot more about how great it is by now.
Anyway, I just thought I'd share my particular experience with it. Good luck man!
Tropical Goat is offline
carb/intake selection Thurber73 1964-1974 Tempest, Lemans & GTO General Discussion 80 10-10-2014 06:32 PM
Jetting and secondary spring selection Bensjammin66 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 07-16-2009 12:25 PM
Valve spring selection for new cam PAULCAPASSO Engine Discussions 24 02-27-2009 08:38 PM
'05 GTO cam install & selection question cat1055man Engine Discussions 45 12-24-2005 05:07 PM
