Carburetor Identification Issue - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-28-2012, 06:32 PM Thread Starter
nuggets's Avatar
Ive always used Holley so quadrajet is somewhat new to me. Im trying to get the identification numbers right so I can get the right rebuild kit. The problem is seems like half of what I need is not there. It is a reman carb, Ive torn the whole thing apart and the only numbers of any ID of any kind on it read as such
4987s
3507.
No other letters, being what i need following these numbers. Ive tried looking up what it means but every site and book tells me there should be other ID numbers after that. Any ideas? Or would it be better to just replace. Carb needs to be rebuilt BAD.
69 GTO 461 4bbl OHV
nuggets is offline
post #2 of 5 (permalink) Old 06-28-2012, 07:50 PM
jmt455's Avatar
Here are pics of typical Q-Jet ID number and position.
Red arrow in first pic points to the stamped ID number and date code:
This is the type of ID number you're looking for:
If yours is a re-man, they might have replaced the stamped number with a tag or ???
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #3 of 5 (permalink) Old 06-28-2012, 07:57 PM Thread Starter
nuggets's Avatar
re
Yes thats where mine is as well. But no letters. Just 4 digits parallel to each other
nuggets is offline
post #4 of 5 (permalink) Old 06-28-2012, 10:18 PM
facn8me's Avatar
17057213 should get ya there. If it is a reman check holley numbers also.
https://www.gtoforum.com/signaturepics/sigpic18842_1.gif
1966 Pontiac Lemans Convertible
389 tri power
facn8me is offline
post #5 of 5 (permalink) Old 06-29-2012, 08:38 AM
lars's Avatar
4987s
3507.
69 GTO 461 4bbl OHV
That's a Carter-built Q-Jet, listed as 1968 - 70 Pontiac application. Unfortunately, Rochester application book does not list the Carter numbers, so you're going to have a tough time getting a "baseline" on that carb. The Carter number is the "4987S" number - that's the carb number, and you can get the correct carb kit using that number. There is no cross reference that I am aware of over to the "correct" Rochester equivalent number, so you're going to have a tough time identifying the correct jetting configuration for the carb.
Lars
lars is offline
Which Carburetor?? wvmtnman 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 02-12-2012 09:39 AM
7040564 Carburetor jhogan2424 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 03-28-2011 10:50 AM
Carburetor PisnNapalm 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 62 01-04-2011 11:38 AM
What Carburetor? kjk990 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 11 09-02-2010 09:55 PM
Carburetor help....please PontiacDave 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 11-12-2009 10:57 PM
