Catch can - Pontiac GTO Forum
 2Likes
  • 1 Post By PontiacJim
  • 1 Post By GTOJUNIOR
post #1 of 8 (permalink) Old 01-28-2018, 06:44 PM Thread Starter
Quoted: 5 Post(s)
Catch can
Looking for some ideas on installing a simple radiator catch can on my 65 goat. Anyone done this? Not looking for a recovery system. Just to keep it from running out onto the street.
65gto is offline
post #2 of 8 (permalink) Old 01-28-2018, 07:48 PM
Quoted: 367 Post(s)
Why is it running out in the first place? Are you over filling the radiator? Some will fill the radiator right to the top. The radiator uses the top of the tank as an expansion area. You should be able to look into the radiator and have the anti-freeze level about 1 1/2" inches below the radiator cap. Should be enough to cover the core.
If you are experiencing the thermostat sticking closed, which happens more than it should with some of the aftermarket thermostats, it will heat up and push anti-freeze out the radiator rather than circulate and remain in the radiator.
Goat Roper likes this.
PontiacJim is online now
post #3 of 8 (permalink) Old 01-28-2018, 07:53 PM
Quoted: 106 Post(s)
^^this^^
No need for a catch can.
Goat Roper is offline
post #4 of 8 (permalink) Old 01-29-2018, 11:48 AM Thread Starter
Quoted: 5 Post(s)
On a really hot day last summer, after driving about 30 miles, I did have it overflowing. Now I have drained the old coolant and replaced, put on a new radiator cap and added a bottle of purple ice. Didn't happen again after that. But haven't driven that much since. Just looking for something simple, in case it does happen again.
65gto is offline
post #5 of 8 (permalink) Old 01-29-2018, 04:09 PM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
For something simple consider adding one of those later black washer fluid jugs w/bracket tight to the core support/radiator punch a hole in the cap and slip the overflow hose into it.
Clearly less visible then those white jugs with the bright red caps. This is what some of us do if we run at the track, as most will not let you make a pass without a catch jug.
1968gto421 likes this.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #6 of 8 (permalink) Old 01-29-2018, 05:43 PM
GTO44's Avatar
Quoted: 39 Post(s)
Was going to mention that gtojunior.
If you drag race at all, per the NHRA rule book:
"Radiator: All cars in competition with any type of water overflow capable of spilling
water must have a catch can to accumulate the excess liquids and prevent leaking onto
the track. Minimum catch can capacity one pint. Catch can must be securely fastened"
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is online now
post #7 of 8 (permalink) Old 02-02-2018, 08:39 PM Thread Starter
Quoted: 5 Post(s)
Don't do any drag racing, but it's kind of embarrassing at the local car show with a big puddle under the car.
65gto is offline
post #8 of 8 (permalink) Old 02-03-2018, 07:20 AM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
Until you can correct the real issue(s) a stealth installation of a washer jug/bracket from a '66 is cheap & easy temporary solution;
Catch Can Wagonbacker9 Engine Discussions 2 09-26-2011 11:23 PM
catch can? RJ_05GTO Engine Discussions 6 02-08-2009 02:20 PM
Best Catch Can Ever!!!!! ELP_JC 2004-2006 GTO General Discussion 10 06-01-2007 06:46 AM
Catch Can Rob in CT Service, Maintenance and Technical Discussion 8 01-22-2007 09:16 PM
