clutch fan removal for 67 gto - Pontiac GTO Forum
 1Likes
post #1 of 16 (permalink) Old 07-14-2019, 07:21 PM Thread Starter
hilton8r's Avatar
I found the original fan shroud in the trunk. It's cracked, but I think it's usable. I've already got the radiator installed. I removed the four bolts that go into the water pump pulley. I also loosed the tension on the power steering pump so I could work with the belts.
I'm really not sure how to proceed from here. Do I need some kind of pulley puller? I'm not having much luck with google. Hopefully I don't have to pull the radiator. I already jacked it up a bit trying to stab this thing earlier. It's hot out. Figured I'd ask, and take a break.
hilton8r is offline
post #2 of 16 (permalink) Old 07-14-2019, 07:36 PM
RMTZ67's Avatar
Quoted: 62 Post(s)
Just wiggle it around.Well that didn't sound good. Tap the fan clutch with a rubber mallet. It just comes straight out.
RMTZ67 is offline
post #3 of 16 (permalink) Old 07-14-2019, 08:26 PM
BLK69JUDGE's Avatar
Quoted: 57 Post(s)
hello ...
on a stubborn fan ,,, I like to either cut a card board box to cover as much of the radiator as i could .. or wrap the blades with a towel
all it takes is a bump ... and its a couple hundo mis take ....
as mentioned above they like to mate together ,,,,, the water pump shaft sticks into the fan clutch about 1/8-3/16" and the ca be stubborn .... sometimes coming off with the pulley helps keep it straight
be safe .....cover it up
oh and ''
on a clutch fan it should be 4 nuts and lockwasehers on STUDS for a clutch
style fan ,,, not bolts ,,,
https://www.ebay.com/itm/Chevy-GM-Wa...-/280904098902
BLK69JUDGE is online now
post #4 of 16 (permalink) Old 07-15-2019, 02:24 AM Thread Starter
hilton8r's Avatar
Originally Posted by BLK69JUDGE View Post
hello ...
oh and ''
I'm ticked at myself for trying to get that shroud in after giving up on removing the fan the first time. It's definitely stubborn. And I may very well buy a new fan shroud since I've gone to the trouble of buying replacement baffles. I definitely don't want to deal with overheating issues. It's too bad I had medical stuff last year. I had planned on buying an aluminum radiator, and possibly electric fans. Cardboard would have been very smart. Thanks for reminding me it's always better to be safe than sorry. And I definitely don't have lock washers or studs, so that's going to change. I'm inclined to pull all of the belts to replace them. While I'm at it, I want to clean up some of the grease and dirt that I'm finding.
hilton8r is offline
post #5 of 16 (permalink) Old 07-15-2019, 02:26 AM Thread Starter
hilton8r's Avatar
It's amazing. I've got so many tools, but a rubber mallet is not one of them. Actually, I'm finding a few tools I wish I had since I started on this gto adventure. Line wrenches are on the list, as well as a rubber mallet.
hilton8r is offline
post #6 of 16 (permalink) Old 07-15-2019, 12:19 PM
Lemans guy's Avatar
Quoted: 54 Post(s)
I am like black69judge,..always put cardboard on the radiator when working up there. You definitely need the lock washer when reinstalling.
Lemans guy is offline
post #7 of 16 (permalink) Old 07-17-2019, 01:47 AM Thread Starter
hilton8r's Avatar
black69judge has got me thinking it's best to pull the water pump to verify it's set up with the correct impeller. I know my car had cooling problems in the past, and the fact that it's using bolts instead of studs tells me it's worth checking out. I don't want to be doing this all over again in the near future because I didn't make an effort to cover all of my bases. I'm going to see if I can source the studs, washers, and nuts too.
hilton8r is offline
post #8 of 16 (permalink) Old 07-17-2019, 08:21 AM
Lemans guy's Avatar
Quoted: 54 Post(s)
a
I use a flow cooler water pump, really keeps it cool. I changed from an 8 bolt water pump on my 66 to the 11 bolt water pump.
If you are trying to keep everything original the you may want the 8 bolt pump. But, the 11 bolt pump is improved and one of the main things is the timing covers are reproduced. The timing covers rot out from hot coolant and years of use and neglect. They are not Re made, so you have to source one or find a reconditioned one. They exist but not so easy.
If you get into the water pump, consider this as your timing cover may be damaged also. Butler Performance web site will show you lots of variables on these options. They sell a conversion kit to go from 8 bolt to 11 bolt pumps, with the new timing cover. Other vendors have them as well.
The flow cooler pump works great, check them out. Everything costs more money, but if you do it right the first time it will save you time and trouble later. Go slow check out the options and assess what you can do.
The internal water pump plate gap is critical on Pontiacs, whatever water pump you use.
You will get it!
post #9 of 16 (permalink) Old 07-17-2019, 04:57 PM
Quoted: 350 Post(s)
Lemans guy: If you are trying to keep everything original then you may want the 8 bolt pump. They are not Re made, so you have to source one or find a reconditioned one. They exist but not so easy."
PJ: KRE offers a new manufacture 8-bolt timing cover with the correct dimple for guys who use the tri-power set-up. Kauffman Racing Equipment
Name:	KRE 8-bolt timing chain cover.jpg
post #10 of 16 (permalink) Old 07-18-2019, 06:10 PM
Lemans guy's Avatar
Quoted: 54 Post(s)
Thanks PJ I stand corrected,...Kaufman has one that is great. So if you pull your WP make sure you examine that timing cover for corrosion.
It would be a good time to change it. I went to an 11 bolt, one reason was the serpentine belt system I used from CVF racing would not work with an 8 bolt pump.
Good to have choices, and good for Kaufman for making the 8 bolt
