Coolant Additive - Pontiac GTO Forum
post #1 of 3 (permalink) Old 05-12-2019, 02:06 PM Thread Starter
Coolant Additive
Hi All,
I have 1970 GTO RAIII with oem heads, 4 core brass radiator. I filled it up with distilled water and one bottle of "wet wetter" and i would like to add a bottle of "Lucas super coolant," but their website said:
"For street vehicles requiring freeze protection, add 1 bottle to 50/50 mix. For racing and high performance applications, add 2 bottles to straight water coolant for maximum temperature reduction. DO NOT use distilled water unless mixed with 50% antifreeze."
I am not worry about the antifreeze cuz the temperature where i live won't go below 38 degree in the winter. so can i add it? Or should i put new distilled water or tap water with 2 bottles?
Recommendations
Aziz2010 is offline
post #2 of 3 (permalink) Old 05-12-2019, 08:06 PM
Quoted: 367 Post(s)
Originally Posted by Aziz2010 View Post
Hi All,
Recommendations
You want to only use distilled water as tap water will have minerals in it that cause the problems with a radiator. I would not use straight distilled water. Use a 50/50 anti-freeze mix. The anti-freeze is not necessarily about cold temps and freezing. It offers a higher boiling point so if your engine runs hot at some point, boil over will occur at a higher temp. You also have the anti-corrosion benefits of the anti-freeze.
I used the 50/50 mix in my '68 Lemans with the 4-core radiator and added the "wetter water" to that. The wetter water did seem to drop the coolant temps. As I recall, the wetter water also helps as a water pump lubricant.
So my recommendation would be the 50/50 anti-freeze mix and 1 bottle of the wetter water additive. I would not use just distilled water and the additive. May be fine for the race track, but I don't think I would go with it on a street car.
PontiacJim is online now
post #3 of 3 (permalink) Old 05-16-2019, 03:59 PM
Quoted: 102 Post(s)
You can take what Jim said to the bank. I run the same combo in my Pontiacs, and have for years and years. No worries.
Zinc additive during maiden start / cam break in FlambeauHO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 21 03-27-2012 10:42 AM
Water Wetter coolant additive asshauler 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 06-03-2011 06:28 PM
fuel additive? Chris-Austria 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 01-28-2011 04:20 PM
??? about diff. additive part # 89021958 Gooooat Drive train, suspension, alignment and brakes. 8 03-03-2006 10:56 PM
