Coolant leak questions - Pontiac GTO Forum
 1Likes
  • 1 Post By geeteeohguy
post #1 of 2 (permalink) Old 09-29-2018, 11:53 AM Thread Starter
Hi all have a Lil project on my hands a 1970 Lemans 350/350 combo no internal work that I know of, maybe a rv cam. My question is could coolant leak into the oil via the coolant cross over on the manifold? The head gaskets were replaced about a year ago, when installing a coolant temp sensor in the intake the manifold cracked and was repaired and warped from the welding on the front passenger side.
70lemonproj is offline
post #2 of 2 (permalink) Old 09-30-2018, 01:40 PM
Quoted: 99 Post(s)
No. Due to its design, you cannot get coolant into the oil from an intake leak. If your head(s) are cracked, different story. If you have coolant in your oil, suspect blown head gasket, cracked head(s), or issues with the front timing cover/water pump sealing areas at the front of the block.
deanhickey likes this.
Ouch! $2984.00 repair due to coolant leak from cylinder head gasket YeomanDroid Engine Discussions 38 10-26-2010 03:56 PM
Engine coolant leak DanielFinzel Engine Discussions 10 07-09-2010 07:17 AM
Sprung a coolant leak yesterday - weird Poncho Dan Service, Maintenance and Technical Discussion 17 05-26-2010 01:09 PM
Unsolved Coolant Leak from overflow tank... Striker222 2004-2006 GTO General Discussion 5 08-20-2006 05:45 PM
Coolant leak GTODAVE05 Service, Maintenance and Technical Discussion 18 11-21-2005 02:18 PM
