Decoding GM Engine Help Needed - Pontiac GTO Forum
post #1 of 3 (permalink) Old 01-05-2014, 10:42 PM Thread Starter
Hi I have A engine in my GTO and wanted to see if anyone can help me decode it to see if possible original or not?
Engine code on block on passenger side.
C 446785 WR
I have a 1968 GTO with a manual transmission.
Any Help is appreciated.
Tom
FireFox3434 is offline
post #2 of 3 (permalink) Old 01-06-2014, 06:18 AM
Tom, this site should help you: Pontiac Power
In order to tell if it is the original engine, you will need to look at the Block VIN number.
Matt
Matthew is offline
post #3 of 3 (permalink) Old 01-06-2014, 02:59 PM
If you're sure of that "WR", then according to the sites I've checked it's not the original engine. In 1968, WR was only used on 350's - and your GTO would have had a 400.
Check the date code (4 characters - 1 alpha followed by 3 numerics, top rear of block, near the distributor hole) - easier to see with a good light and a mirror. The date code will ID the model year. The model year combined with the "WR" will tell us exactly what you've got there.
Engine decoding Inprogress65 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 5 05-21-2012 09:37 AM
1969 GTO engine decoding HELP! Majestic 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 10 02-27-2011 07:41 PM
Decoding locations, engine, trans, heads rigosgto 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 09-10-2010 03:27 PM
Decoding the engine size and year? Need help rnldmdmb Engine Discussions 0 07-25-2009 08:03 PM
Decoding Engine Codes 68greengoat 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 9 07-29-2008 01:03 PM
