Disc brake help. - Pontiac GTO Forum
post #1 of 4 (permalink) Old 01-12-2019, 11:57 AM Thread Starter
RMTZ67's Avatar
Quoted: 64 Post(s)
Disc brake help.
Would 67 gto disc brake cars come with a smaller or the larger power booster? I ordered this set and it came with the smaller one. Fits 65-72 Gto. Are there any advantages to a smaller or larger? Or will there be no difference?
RMTZ67 is online now
post #2 of 4 (permalink) Old 01-12-2019, 12:25 PM
Quoted: 133 Post(s)
Hard to say because you don't have the specifications, but generally a smaller dual diaphragm will produce more assist than a larger single diaphragm.
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #3 of 4 (permalink) Old 01-13-2019, 01:51 PM
Does not make a difference, will give you more clearance with the valve covers.
Lemans67 is offline
post #4 of 4 (permalink) Old 01-13-2019, 03:34 PM Thread Starter
RMTZ67's Avatar
Quoted: 64 Post(s)
Thanks guys. I will post my progress when I get started.
help!! disc brake conversion problem 6t8goat 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 7 07-27-2016 03:45 PM
Drum to disc brake swap help 704dorlemans 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 12 12-15-2015 06:45 PM
1970 front disc swap brake bleeding help!! 704dorlemans 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 10-20-2014 06:10 PM
Right Stuff Rear Disc Brake Installation Help Orion88 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 5 04-17-2014 11:17 PM
Need a little help with the front disc brake lines/setup! tk421 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 5 08-06-2012 07:36 PM
