Does Oil Dipstick on a '65 389 have an o-ring washer? - Pontiac GTO Forum
post #1 of 3 (permalink) Old Yesterday, 01:49 PM Thread Starter
HickBoy's Avatar
Quoted: 11 Post(s)
All:
I recently replaced the valve cover gaskets on my 1965's stock 389. While doing so I moved the dipstick tube while taking out the valve cover bolt and it popped up and out of the engine block.
I was able to successfully push it back down and feed it back into the base of the block and I completed the valve cover gasket replacement thinking everything was great.
Now I am noticing that it's leaking (when there's enough oil pressure) where the tube meets the engine block and leaving droplets on the ground.
I see that on Ames they sell an O-Ring for the Dipstick but I am not sure where it goes. I don't see any mention of it in the '65 Shop manual.
Any ideas? I've included a picture of the bolt I removed and the part of the dipstick that came out as well. I did not see any O-ring on the stick when it popped off.
HickBoy is online now
post #2 of 3 (permalink) Old Yesterday, 03:45 PM Thread Starter
HickBoy's Avatar
Quoted: 11 Post(s)
I apologize as I somehow created two posts when I was trying to update my original... Not sure how to delete the other one...
Below is what I wanted to add.
NOTE: I should add that the base part of the stick is still connected to the block (it appears to be a two piece) and only the upper part is what came loose.
post #3 of 3 (permalink) Old Today, 03:16 PM
Quoted: 114 Post(s)
No 'O' rings were used originally. It is a press fit. If yours came out doing maintenance, it is too loose. You could try to flare it out a small amount so there is resistance, or what I would do: coat the part that slides into the block with Permatex #2 or Indian Head gasket sealer and slide it back in. It'll stay put and won't leak.
