Engine to Bellhousing Bolt Size? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 03-29-2012, 01:16 PM Thread Starter
Wob
I forget to grab a engine to bellhousing bolt off the car last night and need to stop by the hardware store on the way home today to get some engine stand bolts for it. Anyone know the pitch/thread?
Hopefully they have 4" or so bolts that will work. Its a 326.
Thanks.
Rob
Wob is offline
post #2 of 7 (permalink) Old 03-29-2012, 01:31 PM
Pontiacpurebrred's Avatar
3/8in 16 bolts
Have fun!
Pontiacpurebrred is offline
post #3 of 7 (permalink) Old 03-29-2012, 02:44 PM Thread Starter
Wob
Thanks! 3/8" wow would have though that least 7/16".
Oh and I'm having fun....
Wob is offline
post #4 of 7 (permalink) Old 03-30-2012, 09:01 AM
jmt455's Avatar
Wob,
Looks like fun; that's the way to do it!
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #5 of 7 (permalink) Old 03-30-2012, 09:34 AM
lars's Avatar
Hopefully you didn't buy 4" bolts yesterday. Those 3/8-16 bellhousing bolts are only 1.5" long. The factory bolts were a "washer head" bolt" to prevent the bellhousing from getting excessively chewed up by the bolt head - regular hardware stores don't carry those, so be sure to put a flat washer under the bolt head so you don't damage the bellhousing. Lock washers were not used and are not required.
Lars
lars is offline
post #6 of 7 (permalink) Old 03-30-2012, 01:32 PM Thread Starter
Wob
Well remember it needs to go through 2.5-3 inches or so of engine stand tube as well. In retrospect a 3.5" would have worked better, but the 4" worked fine with some spacing. Although that engine is heavy its like pushing a castle around. Why are engine stands three legs again????!!!! So unstable no matter what you do.
jmt -thanks. It's a project for sure!
Wob is offline
post #7 of 7 (permalink) Old 03-31-2012, 02:04 PM
lars's Avatar
Sorry about that - I failed to read your original post correctly: I thought you were looking for the actual bellhousing-to-engine bolts, not understanding that you were buying bolts to attach the block to your engine stand...
Yeah, those 3-wheeled engine stands are awfully unstable when you have a fully-assembled Pontiac on them. I no longer move the engine by pushing it forward due to the tendency of the whole thing to tip - I just push backwards to avoid any potential "situation."
lars is offline
Bolt Size ... jays69covt 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 04-25-2011 04:44 PM
Rear Caliper bolt size? harvotp Drive train, suspension, alignment and brakes. 2 04-11-2010 01:42 PM
Bolt size? 12mm x 1.5 or 1.25? specialk 2004-2006 GTO General Discussion 4 08-10-2006 10:02 PM
What size are the 17 inch rims and bolt pattern 01dakota59rt 2004-2006 GTO General Discussion 4 10-21-2005 01:12 PM
