Engine decoding - Pontiac GTO Forum
post #1 of 6 (permalink) Old 05-19-2012, 11:26 PM Thread Starter
Engine decoding
I'm wondering if someone could help me out? On the front of my block along with the WS for 400 4 speed is a 5 or 6 digit number. Does this number coincide with the vin or something? Is this maybe something I can find on the PHS doc?
Thanks in advance!
Inprogress65 is offline
post #2 of 6 (permalink) Old 05-20-2012, 06:06 AM
No, it won't match the vin --- that number is an "engine build sequence" number that was used in the plant. I don't recall for sure if the PHS doc will have it, check with them.
If you look down lower on the same side of the motor, next to the edge of the timing cover, you should find another string of digits - running up and down. This number will match to your VIN if it's the original engine. I think the factories started stamping the partial VIN on blocks starting in late 1967.
post #3 of 6 (permalink) Old 05-20-2012, 08:48 AM Thread Starter
I'll have to get out there and check, thanks!
post #4 of 6 (permalink) Old 05-20-2012, 11:49 AM
The 5-6 digit engine unit number was listed on the PHS billing history starting in early 67, as bear said in mid 67 part of the car's vin was added to the front of the block.
05GTO is online now
post #5 of 6 (permalink) Old 05-20-2012, 07:58 PM Thread Starter
I looked around for the second number lower on the block with a mirror and didn't see anything. It may have been masked with paint I suppose. Could it have been immediately behind the water pump inlet? That may have been why I wasn't able to find it.
post #6 of 6 (permalink) Old 05-21-2012, 09:37 AM
68greengoat's Avatar
Since the engine vin is stamped, it very well could be filled with paint. Or, since the build date is the 2nd week in July(I read in another thread of yours), it may not be stamped at all. I've read where they were stamped starting in late '67. Not sure what month whether it was mid or late '67. If I remember right, the water pump inlet is in the way.... You can also check the date code cast next to the distributor. Ex D217(7 being '67).
Here's the local:
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
1969 GTO engine decoding HELP! Majestic 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 10 02-27-2011 07:41 PM
Decoding locations, engine, trans, heads rigosgto 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 09-10-2010 03:27 PM
Decoding the engine size and year? Need help rnldmdmb Engine Discussions 0 07-25-2009 08:03 PM
Decoding Engine Codes 68greengoat 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 9 07-29-2008 01:03 PM
Help decoding gtocrazed 1964-1974 Tempest, Lemans & GTO General Discussion 6 06-04-2008 06:41 PM
