Engine gurus step in please - Pontiac GTO Forum
post #1 of 11 (permalink) Old 03-22-2012, 07:41 AM Thread Starter
Pontiacpurebrred's Avatar
As many of you know I am preparing for a 455 rebuild so I have been digging around reading everything I can so that I will be up on the latest tips, tricks and techniques before I start.
I came across this article and I have never heard of this combustion chamber prep but I guess it sort of makes sense. Here is the article from Popular Hot Rodding Mag about a 455 Pontiac rebuild and pictures below of the chamber prep.
DCI 455 Pontiac Engine - Murphy's Law - Popular Hot Rodding Magazine
So discuss, I am interested to see if anyone else has heard of this or seen this.
THANKS!
Pontiacpurebrred is offline
post #2 of 11 (permalink) Old 03-22-2012, 08:58 AM
Quoted: 118 Post(s)
OK. I'll bite: No way would I install hundreds of sharp cornered little hot spots in my chamber and on my pistons. The divots on the piston will hold carbon and cause hot spots, as will the divots in the head....hot spots mean detonation and pre-ignition. Hundreds of little glow plugs ready to get hot and pre-ignite the charge. I did not take time to read the article, but I take it that this is for "swirl" or "atomization". If it was an improvement, the factory would have done it, as it would be a no-cost mod. I am definitely against it. Good way to ruin an engine, IMO.
post #3 of 11 (permalink) Old 03-22-2012, 09:42 AM Thread Starter
Here is the part of the article about the dimpling of the combustion chambers (and bringing the spark closer to the combustion)
Ross provided the forged pistons that Johnston and Milano modified in-house. "We did dimple the tops of the pistons and the combustion chambers to help atomize the fuel," he says. When asked about any empirical evidence that the dimpling did anything to actually help, Johnston referred back to a 409 Pontiac he built for a previous EMC competition. They tested that engine with stock-type chambers first. "It looked fat in areas and the combustion chamber had wet spots where it would puddle in there. I thought, 'You know what, I'm gonna try this.' Because I've seen some articles done on this but I've never seen any testing and nobody knows where to put these things, so I just kind of randomly made it look like a golf ball in the combustion chamber. We didn't do anything to the pistons on that motor." Between just the dimpling of the chamber and also changing the spark plug depth where the electrode would protrude slightly into the chamber, that engine picked up almost 40 hp and Johnston was sold. With the dimpling done to this 455, the pistons and chambers looked like fuel had never touched them. They were also able to run significantly less timing for best power.
I have no clue if it's voodoo or if it might have some good ideas in it.
post #4 of 11 (permalink) Old 03-22-2012, 09:57 AM
facn8me's Avatar
If it was that easy to gain HP stop all carbon buildup all with less timing then every manufacturer would already do it. Kinda like truck tail gates. You think if driving around with a tailgate down actually increased milage evey new truck would have some type of flow thru tail gate as EPA regulations are tough enough to reach as it is. On some engine in a certain configuration it may work. Whaking a piston with a hammer and punch really does not sound like a good idea to me and if it shelled at some point I would not be suprised.
https://www.gtoforum.com/signaturepics/sigpic18842_1.gif
1966 Pontiac Lemans Convertible
389 tri power
facn8me is offline
post #5 of 11 (permalink) Old 03-22-2012, 10:08 AM
Quoted: 118 Post(s)
40 HP gain? REALLY?? If I saw a dyno pull before the dimpling, and a dyno pull afterwards, and there actually was a difference, only then would I even think about lending credibility to this modification. Definite backyard engineering, IMO, and not very credible at all. I don't believe everything I read...."Trust---but verify".
post #6 of 11 (permalink) Old 03-22-2012, 10:20 AM Thread Starter
Thanks guys ... see that's why I bring things to the forum, for other credible opinions.
But really how do you guys feel? Don't hold back? I want to know the truth.
LOL
Thanks again.
post #7 of 11 (permalink) Old 03-22-2012, 03:22 PM
I tend to go with GeeTee on this one. My first thought too was sharp edges = hot spots = detonation city. I read the article and it's unfortunate that they had to run it under the conditions they did (last minute, broken timing light, tune by ear, wrong carb, etc...). I'm very curious though, if I could see a controlled before/after test both with and without the dimples and had some proof from it that they did anything positiive, then I might be convinced -- but I'm not going to buy it on face value though.
post #8 of 11 (permalink) Old 03-22-2012, 04:02 PM Thread Starter
BEAR!!! I was hoping you'd chime in. I, like you, am open to being convinced either way but there was not enough info here to go with it "at face value". That's why I thought I would bring it out in here and see if anyone had heard of such a thing.
I am old school and was always told to polish all the surfaces "smooth is good"
so I was taken aback by this as well. Though as I said before I suppose it's not all "bad science" it kinda makes sense.
I am certainly not gonna do anything like that unless I hear something concrete.
post #9 of 11 (permalink) Old 03-22-2012, 04:04 PM
I've seen intake manifold runners dimpled like this to brake up "boundry layer" air flow but I agree I would'nt want to do it to the combustion chambers or pistons because of the risk of detonation or a place for carbon buildup. If you're looking for that "extra" 5 hp i don't think you'll find it here.
It's either a bandaid for another problem or an attempt at "trick of the week" IMO. If something like this worked I think you would see it in Nascar or some other professional racing where every little bit counts.
post #10 of 11 (permalink) Old 03-22-2012, 04:58 PM
I, not being an engineer, would go on the PY forum and post in the appropriate section.....there are several engineers such as Tom Vaught, and Mark Luhn who will probably be happy to give you an opinion. My heads are already on my motor and I have never seen or heard of the technique discussed in the article......Veeeeeery Interesting !! Eric
Eric Animal is offline
Attn: Electrical/Electronics Gurus... BearGFR 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 32 09-23-2011 05:43 PM
For all you cam gurus out there... Zdenek2334 Engine Discussions 8 09-21-2010 10:17 AM
Question for the VIN gurus... 5hundo 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 11 04-09-2008 10:05 PM
Suspension gurus, enter plaese... Redline Service, Maintenance and Technical Discussion 8 11-16-2005 07:10 AM
Want a Critique from Predator Gurus AGR81 Service, Maintenance and Technical Discussion 3 09-19-2005 07:29 PM
