Engine Ice - Pontiac GTO Forum
post #1 of 3 (permalink) Old 08-21-2013, 05:26 AM Thread Starter
Engine Ice
Hi,
Has/does anyone use a product called Engine Ice instead of regular coolant to help keep the core temp down? Supposedly you can achieve up to 50F less using this product, but it appears to be used more in mortorbike racing, so keen to know if a period 455ci will benefit from this or whether it may in fact cause problems.
Paul
pcolenutt is offline
post #2 of 3 (permalink) Old 08-22-2013, 09:38 AM
I know the owner of EI and talked to him last week about putting some in my '71 with a 350. Here is what he told me:
"As for "will it help," I don't know, individual results vary. Does it run hot now? If it does, it might help, but if it doesn't, then you likely won't see any visible difference. Keep in mind, if your engine is not running hot, how cool it can go down is limited by the thermostat. Even if you fill the engine with ice cubes, it's only going to go as low as the thermostat allows, because it will stay closed until it reaches it's desired temperature.
Now, if you do not have a temperature issue, but just want to use a good product free from contaminants like dissolved minerals and chemicals that can crystalize and clog the system, then Engine Ice is a good product for you."
cobra314 is offline
post #3 of 3 (permalink) Old 08-22-2013, 10:21 AM
That information is basically for a stock type engine. For a race engine Engine Ice would be very beneficial. I used it in my Honda CRF450 and it worked great. I never overheated and I live/rode in Oklahoma during temps of 95+.
cobra314 is offline
"engine ice" coolant Chris-Austria 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 05-05-2011 08:57 PM
Ice Scraper fergyflyer The Lounge 6 01-25-2009 08:58 AM
Damn Ice alsgto04 The Lounge 20 12-06-2008 03:36 PM
Uhh. Ice? pickinfights Service, Maintenance and Technical Discussion 6 02-04-2007 07:51 PM
Turtlewax Ice dakim Exterior Discussions 14 05-14-2006 12:35 PM
