Engine missing at cruise RPM - Pontiac GTO Forum
post #1 of 15 (permalink) Old 12-19-2012, 04:30 PM Thread Starter
FlambeauHO's Avatar
Quoted: 8 Post(s)
So I drove the car yesterday and I am getting a pronounced bucking/misfire at cruise RPM, tach isn't working currently but its from off idle to maybe 3000. It is most noticeable at steady RPM's... Was going to see if anyone had any suggestions, I will be going through the cap, rotor and wires to check for ignition issues. ALso my Holley 750 has not been rebuilt in at least 15 years so it could be the culprit. That said I am looking for a rebuilt quadrajet if anybody has one at a decent price. There are a few on ebay for 175-200 already rebuilt but they are for 1973's and I wanted to make sure they would work. Ideally I would like to procure the correct 400HO auto carb for 68 7028268.
FlambeauHO is online now
post #2 of 15 (permalink) Old 12-19-2012, 05:09 PM
Quoted: 118 Post(s)
I had the same issue a couple of years back with my '65.....thought for sure it was carb related, it wasn't. It was too much advance at cruise due to a worn vacuum advance can bushing. Disconnect your vacuum advance and go drive the car. If the problem goes away, you need to cut the total advance down with a new bushing kit or an adjustable vac advance can. It'll take you 2 minutes to check, and then you can rule it out if the problem persists.
post #3 of 15 (permalink) Old 12-19-2012, 05:55 PM Thread Starter
FlambeauHO's Avatar
Quoted: 8 Post(s)
Thanks geetee, I'll give that a try.
post #4 of 15 (permalink) Old 12-19-2012, 06:06 PM
jmt455's Avatar
Advance idea is a good one.
Also, make sure you're not getting cross-firing between #5 and #7 cylinders. Happened to me when I had a cracked spark plug. Can also happen if those two plug wires are running parallel and near to each other.
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #5 of 15 (permalink) Old 12-19-2012, 08:11 PM Thread Starter
FlambeauHO's Avatar
Quoted: 8 Post(s)
Thanks, I'll fire it up in the dark this weekend and break out the spray bottle. I still want to find me a quadrajet
post #6 of 15 (permalink) Old 12-30-2012, 11:06 AM Thread Starter
FlambeauHO's Avatar
Quoted: 8 Post(s)
Geetee, ran the car without vacuum advance connected and still had the stumble.
Didn't see any wires that looked like they were cross firing. I should have my new carb here in a week of two and I'll also grab new plugs and wires for grins. If that doesn't get it I'll dig deeper
post #7 of 15 (permalink) Old 12-30-2012, 11:44 AM
Not sure if this could be contributing to your problem, but I had a similar stumble problem at high rpm and I found that my older plugs needed replacement.
olde-goat is offline
post #8 of 15 (permalink) Old 01-01-2013, 01:02 PM Thread Starter
FlambeauHO's Avatar
Quoted: 8 Post(s)
Thanks olde goat, I pulled all plugs and inspected yesterday, they look excellent. Inspected all wires and pulled cap and rotor (accel HEI) and after a test drive I think the problem may be gone. Maybe a wire was arcing or the seal between the coil and cap could have been on the wrong side of the carbon button. I don't know but I'll post when I figure out more.
post #9 of 15 (permalink) Old 02-15-2013, 06:37 PM Thread Starter
FlambeauHO's Avatar
Quoted: 8 Post(s)
Re: Engine missing at cruise RPM
Problem is still there getting ready to rebuild my Quadrajet pretty soon so I may wait to do anything drastic. Problem is Intermittent and sure feels like an electrical issue but could easily be the old ass Holley. The problem is hard to describe and not serious, just enough to piss me off a lot! Might throw new wires and plugs on this weekend.
post #10 of 15 (permalink) Old 02-15-2013, 09:10 PM
jmt455's Avatar
Could be a flaky pick-up or ignition module.
Does the accel HEI have the moving advance plate with the two wires? A fraying or broken pickup wire can do this.
1968 Pontiac GTO
jmt455 is offline
What am I missing here??? 1968 Q8 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 14 03-12-2012 04:05 PM
2005 LS2 GTO missing on 2,4,6 and possibly 8. Josh05ls2 Service, Maintenance and Technical Discussion 9 01-13-2012 08:38 AM
intake missing something 68GTO4004Spd 1964-1974 Tempest, Lemans & GTO General Discussion 4 06-30-2011 08:45 AM
missing my car... xcmac26 1964-1974 Tempest, Lemans & GTO General Discussion 23 07-02-2010 04:47 PM
0-60, What am I missing? noz34me 2004-2006 GTO General Discussion 9 02-16-2006 10:06 PM
