Engine removal - Pontiac GTO Forum
post #1 of 10 (permalink) Old 10-12-2013, 02:13 PM Thread Starter
Engine removal
Looks like I will be pulling the engine out of my sons 68 goat
We are going to have it rebuilt, will get more into that later.
Where are the best points for attaching the chain for pulling out the engine ?
Been better then 35 years since the last engine I pulled
Also what's easier, pulling trans with engine or drop trans out first.
Bill
bondobill is offline
post #2 of 10 (permalink) Old 10-12-2013, 05:47 PM
Dunno about "best", but since I've got one of those engine leveler doodads with the long-screw and 4 chains coming off it, I secure it with good grade-8 bolts into the 'corners' of the intake manifold. Make sure to use bolts that are long enough to get a good 'bite' into the threads.
I've found it's less hassle to pull the engine and tranny separately.
post #3 of 10 (permalink) Old 10-12-2013, 09:04 PM Thread Starter
Thanks Bear
I got one of them there doodads you be talking about ......
Now it comes back to me what it is for
Going to have a whole lot of questions, once we get it apart.......
Hope you don't mind
Bill
post #4 of 10 (permalink) Old 10-12-2013, 09:37 PM
No problem at all.
If your leveler has angled steel tabs on the ends that the bolts go through like mine does, be sure to orient them so that the weight of the engine tends to "spread" them instead of going the other way. Going the other way tends to cause them to obscure the bolt, making it "interesting" to remove
post #5 of 10 (permalink) Old 10-13-2013, 09:59 AM
rvp986's Avatar
Bear... For us younger guys, would that be called a "Cherry Picker"? If so, thought they were only used for pickin' Cherries? No wonder I found it a lot a work pickin' Cherries.
rvp986 is offline
post #6 of 10 (permalink) Old 10-13-2013, 12:23 PM Thread Starter
Thanks again Bear
Is there any reason why I even need to remove the trany and bell housing , or does it make it easier for reinstall
The trany...4speed .....was just rebuilt along with a new clutch.
post #7 of 10 (permalink) Old 10-13-2013, 01:43 PM
Jared's Avatar
Quoted: 5 Post(s)
I have seen it done both ways. One of my friends had a 1970 Olds W31 with a 4 speed. He disconnected the bell housing from the block to remove the engine. I wasn't around when he reinstalled, but he did the entire job without dropping the trans. I would have thought it would be difficult to line up the input shaft and the clutch. This same guy did the same thing on a 69 Shelby. So the answer is it can be done. I would suspect that the reinstall would be easier without the trans in place, especially on a standard shift car.
Good luck with it!
Jared is offline
post #8 of 10 (permalink) Old 10-13-2013, 03:03 PM
Quoted: 118 Post(s)
I've done it just about every way. The one that works best for me is to bolt the chain to the back of the passenger cylinder head (by the coil mount bracket) and cross it over to the front of the driver's side head. The cherry picker hook can be moved to center the load very easily. Separating the engine/trans gives much more wiggle room with much less chance of damage, especially on the install. Good luck.
post #9 of 10 (permalink) Old 10-14-2013, 12:04 PM
68GTO4004Spd's Avatar
Remember to support both the front of the tranny and the rear of the engine before seperating. Do I smell a 461 stoker in your future?
68GTO4004Spd is offline
post #10 of 10 (permalink) Old 10-14-2013, 03:26 PM Thread Starter
Yea that's what we are thinking, maybe a set of aluminum heads
Looks like we will be rebuilding it a few years earlier then planned.
Whether we use this block we will wait and see once it's torn down. We have available if we want it a 400 block out of a 70 Goat.
We are not going to rebuild it ourselves...I know my limitations...Brent and I are pulling it at home.
Worked some on it this weekend, should be able to have it on the ground some time this week, then it will be off to a couple of local guys that have been building engines for years, actually one of them worked for me 10 years in my body shop.
engine and trans removal dmassetti 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 12 10-07-2013 09:11 PM
engine removal question Reb 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 6 10-02-2013 06:06 PM
engine removal denf221 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 6 04-09-2010 11:18 PM
Engine removal problem sixeightGTO 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 8 02-15-2010 09:40 PM
Do you have any engine removal tips? bsman Engine Discussions 14 03-31-2009 12:52 PM
