Engine Swap Question - Pontiac GTO Forum
post #1 of 8 (permalink) Old 01-12-2013, 01:29 PM Thread Starter
Hello, i have a question that hopefully someone can answer....my 1967 GTO is going to be down for a good while and not driveable ...its has a 400 engine with a 4 speed transmission. I currently have a 1971 chevelle that the engine is shot in it and my question is how hard would it be to put that 400 in my 1971 chevelle. Would the pontiac engine hook up to the chevrolet transmission, if not how difficult would it be to transplant the pontiac engine and transmission both into my chevelle. Thanks, hopefully someone can help me out with this.
revOlg1206 is offline
post #2 of 8 (permalink) Old 01-13-2013, 07:49 PM
Quoted: 117 Post(s)
Not hard at all. The fuel lines and speedo cable are on different sides, and the battery may be, as well. Little stuff. The chevy trans, if an automatic, will not bolt up. You need a BOP patterned automatic trans. A chevy four speed will bolt right up, though.
post #3 of 8 (permalink) Old 01-13-2013, 08:46 PM
Josh.AZ.GTO's Avatar
Starters, oil filters are opposite of each on Pontiac vs Chevrolet. Pontiac motors are wider as well. You will need a BOP bell housing for your 4 spd to mate up.
Sent from my iPhone using AutoGuide.com App
JOSHUA
1970 GTO 455HO Cardinal Red
Josh.AZ.GTO is offline
post #4 of 8 (permalink) Old 01-14-2013, 05:33 PM
Do it Do it Do it !!!!!
If for no other reason that to, in some small way, counter-balance all the Pontiacs out there that have had to suffer through having a bow-tie put into their engine bays against their will....
post #5 of 8 (permalink) Old 01-14-2013, 10:05 PM
confused Does not register. confused
post #6 of 8 (permalink) Old 01-15-2013, 10:48 AM
Aw man.... Sorry about that Sometimes my mouth overloads my good sense (what little there is of it).
post #7 of 8 (permalink) Old 01-15-2013, 12:03 PM
Quoted: 117 Post(s)
Stand your ground, Bear. We're all behind you 100%!!!! I would LOVE to take a restored Chevelle SS to a Chevy event/show with a Pontiac mill under the hood. I'd hide a recorder under the hood to capture all the comments!!! Alky is just having some fun.....
post #8 of 8 (permalink) Old 01-15-2013, 07:09 PM
I think a Chevelle with a hard running Pontiac motor would be very cool. I'd have to try and make it run as good as Jim Wangers PonteCarlo. I believe that car is street legal and running 8's.......
As an aside, I once knew a guy with a Ford truck running a 440 Chrysler engine. The only external giveaway were the little gold pentastars on the front fenders and a Dodge Ram on the hood. Fun stuff.
Originally I bought the GTO as a project to put a 455 Buick in, but changed my mind.
'04/'05 engine swap into '66 MAXXFJ 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 02-26-2012 08:44 AM
64 GTo engine swap Larry1945 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 6 11-30-2010 07:51 AM
Engine swap on a 70 and 66 jetstang 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 23 05-28-2010 07:23 AM
Engine swap, 250 6 cyl to 400 8 cyl Braveheart61 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 08-16-2009 12:28 PM
69 GTO 455 engine swap pbkgto 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 8 04-16-2009 08:34 PM
