fuel pump question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-07-2018, 10:54 AM Thread Starter
T_Top_Tony's Avatar
fuel pump question
Hello. This is my first post so wanted to say hello first. I have a 70 LeMans with a dying 455 buick engine in it. I found a Pontiac 400 on Craigslist that seem so far to be in great condition. Only issue is they removed all the accessories and boxed it and lost that box. So I am piecing together pulleys, brackets, distributor... right now. My question is I have the mechanical fuel pump right now but no pushrod for the fuel pump. No matter where I look I cant find a listing for a fuel pump pushrod for a Pontiac only a Chevy. So does anyone know if GM used the same size pushrod for all its engines? Or maybe a part number for a Pontiac pushrod?
Thanks in Advance
T_Top_Tony is offline
post #2 of 3 (permalink) Old 02-07-2018, 11:59 AM
Quoted: 55 Post(s)
Welcome to the GTO Forum !
Pontiac V8's do not use a pushrod. The fuel pump has a long arm, which is moved up & down by the fuel pump eccentric, which is bolted to the end of the camshaft.
https://www.google.com/search?q=pont...hrome&ie=UTF-8
Some choose to block off the fuel pump mounting hole & instead use an inline electric pump, back near the tank. Some use both, switching the elec pump on, only when needed.
Name:	Fuel Pump Eccentric .jpg
bigD is online now
post #3 of 3 (permalink) Old 02-07-2018, 02:13 PM Thread Starter
T_Top_Tony's Avatar
well sun of a gun no wonder i cant find any info on it. Thank you for clearing that up! That is pretty neat though this is my first non chevy and I didn't realize how different (innovative) these engines are.
Fuel pump question 66 gto rick3452 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 11-23-2012 08:14 PM
Different Fuel Pump Question Pontiacdude 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 05-13-2011 04:59 PM
fuel pump question... Instg8ter 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 05-12-2011 03:32 PM
Fuel Pump Question Jim 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 05-12-2010 09:19 PM
06 fuel pump question 06GOAT Engine Discussions 2 05-09-2008 06:32 AM
