good engine test stand? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 02-10-2012, 10:25 PM Thread Starter
any of you guys out there have any experience with engine test stands? Any good models that are decently priced? I don't want to spend a ton on it but I am really looking at getting one so I can run in my new engine when I get it (mostly to see if it got ripped off or if anything is wrong with it).
I have found one that is a very good price but I can't find any reviews on it. here is a link
http://www.amazon.com/Larin-METS-1-Mobile-Testing-Station/dp/B0007NXVB0
There are lots of other that I found for 2 g's but that is to much for me to spend since I have plenty of other parts I need to finish the car.
Thanks guys
Scott
Bigalsworth is offline
post #2 of 6 (permalink) Old 02-10-2012, 10:58 PM
facn8me's Avatar
Can you weld? Not really much to it. Could probably get one built for less than 2k also. Any fab metal shops around? I have seen medical equipent stand used as one too. A few gauges. Toggle switch and starter button. Thats a fairly good price on the one you linked. Pretty much has it all.
https://www.gtoforum.com/signaturepics/sigpic18842_1.gif
1966 Pontiac Lemans Convertible
389 tri power
facn8me is offline
post #3 of 6 (permalink) Old 02-10-2012, 11:01 PM Thread Starter
I can kinda weld. but I would spend as much buying the welding equipment as I would buying a cheap test stand. But I'm sure I could find a few fab shops that could put something together, pretty good idea.
post #4 of 6 (permalink) Old 02-12-2012, 09:48 AM
Another option for you, depending on where you're at with your project: put the engine in the car and just rig up direct "hot wire" connections to the battery for ignition and starter. I broke my engine in on a dyno at the machine shop, but after I got it home I put it in the frame and ran it a few times a month for just over a year until the car was finally drivable. Neighbors are appreciative if you also install the exhaust system with mufflers...
post #5 of 6 (permalink) Old 02-13-2012, 11:14 PM Thread Starter
I had a friend suggest the same thing bear and it really does sound like a good idea. I think I will go that route thanks
post #6 of 6 (permalink) Old 02-14-2012, 12:45 AM
AlaGreyGoat's Avatar
You could get the cheaper one you listed and get a radiator and take it to a local vocational school. They should have the metal to mount it and any mods you want. They will do the work, usually for only a small donation.
Larry
AlaGreyGoat is online now
Engine Stand Mount Hardware Josh.AZ.GTO 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 5 12-22-2011 11:37 AM
Good Engine Rebuilder? Chicago area? vbaron21 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 02-08-2010 07:43 AM
wheel stand REDGTO89 The Lounge 5 11-05-2008 05:16 PM
Slight Engine Mods for Good HP 04BlueGTO6spd Engine Discussions 11 03-04-2006 09:04 AM
Does GTO stand for... robincw 2004-2006 GTO General Discussion 3 09-10-2004 01:17 PM
