Guide plates for 142 heads - Pontiac GTO Forum
post #1 of 4 (permalink) Old 07-31-2012, 09:16 AM Thread Starter
SPCMarty's Avatar
I had these converted to ARP screw-in studs, and neither the factory guide plates I have nor the PRW plates would fit.
By fit I mean the holes for the studs do not line up or are even large enough.
Are there another type that'll fit, or do I even need them?
B. Co. 1-22 Infantry 4th Infantry Division OIF 2008-09
1971 LeMans 350ci 2Barrel Carb
B. Co 1-22 4ID OIF 2008-09
SPCMarty is offline
post #2 of 4 (permalink) Old 07-31-2012, 11:23 AM
I wouldn't run without them myself. The factory plates should work just fine after you drill the stud holes just large enough so that the threaded end of the stud will pass through them. If they won't line up after doing that, then I'd be suspicious of whoever did your machine work because that means they've changed where the stud center-lines are. That would give me pause....
post #3 of 4 (permalink) Old 07-31-2012, 02:49 PM Thread Starter
SPCMarty's Avatar
The heads didn't have guide plates in the first place, does that make a difference? The factory ones I robbed from my #13
SPCMarty is offline
post #4 of 4 (permalink) Old 07-31-2012, 11:47 PM
factory guide plates will fit all Pontiac heads if proper machine work was done.
pontiac is offline
'68 GTO / LeMans VIN Plates? SixTeight 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 3 06-11-2011 01:12 PM
69 GTO Frame Off, Need a guide masterblaster 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 7 11-01-2010 08:26 PM
plates poll! Nate GTOforum Polls 10 05-28-2010 05:56 PM
Plates are in Aramz06 2004-2006 GTO General Discussion 3 06-30-2008 07:43 AM
If your looking for aussie plates. HTRDLNCN The Lounge 4 05-10-2006 05:03 PM
