Heater hose location - Pontiac GTO Forum
post #1 of 2 (permalink) Old 09-02-2018, 11:17 AM Thread Starter
Ohio66GTO's Avatar
Quoted: 14 Post(s)
I have a 1968 428 that is in a 1965 GTO. There are two spots on the firewall for the heater core. The hose that comes off the head goes to the lower “inlet” and the hose that comes off the upper “outlet” runs to the water pump. Is this correct? Here is a picture of how I have it setup.
Ohio66GTO is offline
post #2 of 2 (permalink) Old 09-02-2018, 02:26 PM
BLK69JUDGE's Avatar
Quoted: 62 Post(s)
Hello
looks great under there !!
I think 65 had an inner fender bracket to hold the hose up ...
68 had a bracket on the front of the head ... for support
I do see 1 item that will give you an issue .... it is the bracket for the manual choke ,
you need to get it as close to the choke as possible ... 2" .... maybe back carb bolt or ?
that cable will bend when you go to push the choke in one day .... and not open the choke ...
looks great !! oh and move the lift loop to the pass upper timing cover bolt ...
nice job on the pl ug wires ....
Scott t
BLK69JUDGE is online now
Heater Hose routing RunninLeMans 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 06-19-2014 06:14 PM
block to heater core hose gjones 1964-1974 Tempest, Lemans & GTO General Discussion 5 05-26-2013 02:30 AM
heater hose and valve plumbing question mikezohsix Service, Maintenance and Technical Discussion 2 02-20-2011 08:48 PM
Question About Cyl Head Heater Hose Nipple peahrens 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 3 12-01-2010 09:19 PM
