Intake Manifold diagram??? Anyone have pics? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-25-2019, 02:03 PM Thread Starter
Quoted: 4 Post(s)
Hey guys,
I'm recently picked up a 66 gto partially frame off restored. I'm working on getting the motor running and need help determining the correct running of all of the vacuum lines. does anyone have a diagram or can anyone take pictures of which vacuum line connections lead where? there is also a hose barb under the carb I dont know what line is supposed to go here. Thanks in advance for the help.
Cam
gmjunkie is offline
post #2 of 3 (permalink) Old 02-26-2019, 07:26 AM
Quoted: 126 Post(s)
Originally Posted by gmjunkie View Post
Hey guys,
Cam
All the vacuum lines ????
If all you're trying to do is "get the engine running" - just block off any open vacuum ports.
You should have a line going to vacuum advance (distributor); one going to the power brake booster (if you have power brakes); one to the PCV valve; and one more if you have an automatic transmission for kick down...
Name:	Motor from top.jpg
ID:	117849   Click image for larger version
Name:	Motor front.jpg
ID:	117851   Click image for larger version
Name:	Motor drivers side.jpg
ID:	117853   Click image for larger version
Name:	brake booster.jpg
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #3 of 3 (permalink) Old 02-26-2019, 07:32 AM Thread Starter
Quoted: 4 Post(s)
Cij911, I appreciate the response. But I also should have specified I have a 4 barrel intake. I was moreso trying to figure out which vacuum port is factory correct each vacuum line. Especially the barb located underneath the carb. I’m finishing the restoration so I’m not sure where those lines were originally run to.
Thanks for the pictures tho, eventually I’ll be swapping over to a tri power intake and this will definitely help.
God, Country, Cars
gmjunkie is offline
Anyone Have a '74 GTO Wiring Diagram? 74GTORestoration 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 12-08-2016 07:06 PM
Anyone Have pics of tinted tail lights on PBM with/without black valence? batmans Exterior Discussions 11 04-12-2010 10:42 AM
Anyone have pics of 70 GTO with torque thrust II wheels? azmusclecar 1964-1974 Tempest, Lemans & GTO Wheels & Tires 2 10-07-2007 10:08 AM
Anyone have pics? of a Silver GTO with Black or Gunmetal rims? specialk 2004-2006 GTO General Discussion 6 06-21-2006 03:54 PM
Anyone have pics of the Cosmo Purple? Z16Z06 2004-2006 GTO General Discussion 2 12-24-2004 04:10 PM
